Most Realistic Console Bathurst?
Have a G25 wheel and pedals setup, need to get the game and the console that will preferably work with said G25. Other than that, the first priority is the ability to do realistic solo laps in a V8 rear drive car that will help me in reality. What are your recommendations dear sirs?
https://www.sau.com.au/forums/topic/469587-most-realistic-console-bathurst/
Well it depends on if the g25 is supported by the ps4. Of not check if it's pc supported. It should be. Those would be the options hardware wise.
Games I'd look at is project cars and assetto corsa. I've only played project cars. It's pretty good played it with a controller and it was horrible got myself a g920 and it was heaps better.
Assetto corsa might be better but can't coment on it.
Pc might have more game options too.
Whilst the ps3 gran turismo is the easiest and cheapest method dunno if it is now "most realistic" as title stated.
Ps4 has heaps of wheel support. G29 is the current logitec wheel for it and I think there are thrustmaster options and also fanatec but they're more expensive.
Something I realised is you also wanted v8. Is that supercars? If so dunno if project cars or assetto has fhem. Not sure about gran turismo either.
9 minutes ago, MatthewT85 said:
Ha ha true maybe one day I'll upgrade. What's the price on a fanatec?
North of $1,000 for club sport pedals, steering box and wheel.
The BMW steering wheel feels as if it got pulled out of a race car.
Any chance of sharing a link about the steering wheel support on the PS4 mate?
f**k thats a big investment...
http://gaming.logitech.com/en-au/product/g29-driving-force
http://www.thrustmaster.com/en_UK/products/t300-rs-gt-edition
I've found Project cars to be one of the better, if not the best thus far. I have driven a v8 around bathurst for COUNTLESS laps on project cars.
Forza has been up there for a while, not sure if the new one has bathurst? as the old ones didn't.
Data loss, try again :)  Thanks a lot blokes for the useful info and suggestions, my real track car has a LS3 V8, see avatar pic. So what the game/simulator must have is something similar, a rear driver V8. Maybe a Corvette or even a old school Falcon GT, that 7 litre Commodore special would be great.
There's videos on YouTube which compare Bathurst on forza vs gt6. Forza looks great but it doesn't have the same tarmac undulations as gt6 does. And if I recall correctly, GT actually go to each track and map it out so it's as accurate as can be.
Gt6 also gives you 2 commodores and an au Bathurst car. For your v8 pleasure.
Had a quick look on YouTube without noting which system, a couple of strange dynamics came up. One outside view showed the car apparently pivoting around the centre when turning and moving around, instead of moving from either or both ends eg car turns right so the front should lead by moving to the right and the rear follow, depending on slip of course. The other was very strange. The car went into various angles of slide in every corner with the front particularly sliding as if on ice without losing speed, in real life the tyres would last maybe a lap and usually the car would not recover from such slides.
So I'm wondering if this sort of behaviour is optional and the cars can be tuned to drive like a real race car. If so, which game is best at that?
Edited by 260DET
You are never going to get the same feel as actually driving a track as in the end it's a game and can only be made to be as realistic as the system allows it. You won't get the proper feel of all the bumps or weight of the car or anything like that.
The only thing I can think of that would even come close to what ur after ( as realistic as driving the track) is a simulator that an f1 team would use
Use to play a PC V8 SC game years ago where the car could be backed in to a corner at some sort of ridiculous speed and then gunned out. Really it was not too bad though but I had sort of hoped that things had moved on since then. Whatever, any one of the console games will help learn the circuit.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
