Trying to get motivated on the shed again.
Electrician has been out and confirmed I can run power from the other shed (good news). Just teeing up a trencher and supplies to go in the ditch (storm water also).
In the meantime, I had gone back and forth about what to do with the slab. I couldn't justify 2k in materials plus my effort to epoxy it knowing what's going to be going in and out and what it's driving on/through the get to the shed (red clay/dirt/gravel etc). I was mainly wanting an epoxy/painted finish for the uniformity as the slab is just ugly as f**k with trow/helicopter burns and pigment/oxidization differences where batches of concrete meet/the surface was finished too dry etc.
Concrete supplier is comfortable the mix is fine and the slab is sound but that it's not "ideal" aesthetically. I didn't bother chasing the concreter himself because he was a tool bag which is why I axed him after the slab and got a different crew to build the shed. He came recommended from another member in the car club.
I didn't want the hassle/cost/risk of going hard core on the acid etching as a test showed it was already at a good porosity for accepting sealer (plus the shed is above a water course). Grinding is also messy/costly etc so in the end I'm just accepting it as an ugly rural slab that's going to get worse thrown at it anyway.
I wanted some level of oil protection and sealing so just ended up opting to use the same sealer I used on the last shed and had no issues with, there was also a mix up with how much I needed and I took some of it back which resulted in some kind of double refund so I've effectively paid $0 for the materials to seal it.
The types of discolouration I mean, there's also differences in surface texture as you can see in other pics where the light behaves differently off the sealer (3 coats with grip additive).
20210203_122750.thumb.jpg.46ede7e1eb9a78fdfb3e5e00b2a6cd96.jpg20210203_122755.thumb.jpg.2acdbd307c2fa3338c9b9cc0f7d8b350.jpg
I did use a neutral concrete wash on it first and pressure washed the shit out of it to find that some of the foot prints I'd left on it myself, red clay, refused to come out fully and apparently require special chemicals to break down the iron oxide....
Anyway, I guess that will have to do and I'll just press on with power/fit out.
20210203_123412.thumb.jpg.c544290d4b945943ff1df91355482c8f.jpg20210203_123556.thumb.jpg.555d69f032f5afe0e3d5f31c4b189080.jpg20210203_124907.thumb.jpg.3cadb8424a5f5484201c410dcde32354.jpg
Edited by ActionDan
  • Like 2
Hoping to get the apron poured in a week or 2 with my usual/preferred concreter. He also had a look at the slab "bit ugly, but nothing to worry about".
He was mostly interested in where the hoist pad is (200mm thick 3.6m wide section, double mesh) and was happy with that.
Hoist is gonna be a life changer.
Yeah it is sure easier on the back with a hoist.
I got my slab epoxy sealed (with a flake finish because it hides uneven-ness). I did cost a(nother) couple of thousand and they did a bit of grinding to get the surface right.
We have the same issue with dirt tracking in, this is what it looks like with daily use on a rainy year. A broom every now and then and probably an annual pressure wash is all it needs but it looks good, keeps fluids spills up and is not slippery so I am very happy.
No idea how long it will last, it has been down 18 months with no issues yet. The paint I had on my previous garage was lifting in some places where I'd had sticky tyres on hot days after about 5 years and I wasn't looking forward to redoing that. I've got unsealed concrete in the farm shed and that is impossible to deal with the oil leaks.
Cheers Duncan, matches everything I've seen and heard.
Wasn't willing to spend the extra and have the hassle in the end for what is just a big farm shed.
I've seen some nightmare stuff with epoxy lifting and having to try and repair patches from impact damage etc.
This product is very forgiving, can be applied straight over top of itself with no special prep/actions and still keeps the oil out.
Good enough for me.
Looks like apron going on this week too :)
The roof is done with aircell which is pretty normal for most sheds. I won't do walls as it seems fine in there on days that I'd be wanting to work in there anyway with the whirlybirds.
I "might" chuck a swampy on it, maybe.
For a house you'd do proper insulation and plaster it in, roof and walls.
Sheds are cheap for lots of reasons, partly because they are not classed as habitable structures to council.
  • Like 1
You can certainly put proper insulation in the roof/walls and plaster/mdf/plywood line it for substantially better temp control.
You don't often see it done that way.
I did consider a toilet, but for the hassle/cost/compliance for the rare times it'd be used, not worth it for me. Same with shower.
I'll probably chuck some poly into the trench with the storm water/elec so I can have a tap on the side and maybe a sink inside. I had a sink in the last shed and it almost never got used so dunno if I will bother with that I've got an ultrasonic cleaner now so if I'm washing something it'll go in there and if I need to rinse it off I can just use the tap outside.
I think the water is worthwhile. I've got 1000l cube catching some of the rainwater at my shed and use it a fair bit for washing/rinsing stuff and hand washing. No drain/waste of course, just runs to ground nearby
Yep, the other shed is already connected to a 33kl tank which is always full, I'll only connect one side of this shed to it (incase the other shed ever gets disconnected/removed).
The other side will just go to overflow, we have so much bloody water here.
I probs used the sink previously mostly for hand washing lol
  • Like 1
  • 2 months later...
Builder is back on deck, has been lots of stuff going on his end - lucky there was no rush lol
Decision was made to CNC the chambers, builder says;
"The chamber's will make the engine much more efficient essentially, usually 4-5 psi less for same HP"
"Torque gain would be 40-50nm"
"Top end hp probably not so much, but far less chance of detonation so more stable timing map, it'll be far more knock resistant"
All sounds good to me and not huge money, head has not had mounting surface machined yet so that will be adjusted to ensure comp lost is regained.
Apparently the limiting factor for power/torque and longevity (given a suitable turbo) will be the block strength itself now. Extra work has been done in the bottom end on the mains, skirts, and to the girdle to tie it all together, but it's not sleeved nor are the coolant passages between cylinders "wedged", his view, based on what Nismo do/have seen, is that these are a false economy and cause more stresses in other places that then crack anyway. Seems like a hot topic, I see valid explanations and opinions from a number of good sources for and against so I'll go with what the builder reckons.
I'm not aiming to run it at absolute max output anyway, the head room is there to ensure it can do what I want as easily as possible.
Still on the fence about if I just sell the long block (buy a basic forged SR/do a basic forged rebuild on CA and then have a weekender as well) put it in Silvia, or put it in something like an 86 (or something else with a better chassis than the S13) etc etc.
NFI how to really make that call so have kept putting it off until engine is here.
Edited by ActionDan
  • Like 1
  • 3 weeks later...
@robbo_rb180 boarder restrictions dis dat, actually no idea. Workshop building my motor taking ages, then again I did send them a motor with a destroyed head and cracked block lol.
  • Like 1
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
