R33 Haltech Wideband Install
Hi All,
I'm looking at getting a Haltech wideband sensor, controller and gauge for my R33 GTST so I can keep an eye on my car closer. In particular, this kit from Golbeys https://www.golebysparts.com.au/parts/view/2994/386/can-expansion-products/can-wideband-controllers/ht-059960-wbc1-single-channel-can-wideband-gauge-kit because it is a CAN product and can tie in with my existing Haltech Platinum Pro ECU (i.e. not just a gauge)
Would I need to do anything out of the norm to set it up? I've read about adding it to the ECU in ECU manager but will that cause any issues with the existing tune? I would like to have the gauge and the ability to log without affecting anything already configured.
In addition to the above has anyone used this on here before and have they had any issues?
Cheers!
https://www.sau.com.au/forums/topic/470097-r33-haltech-wideband-install/
Better off just getting a standalone unit and feeding the 0-5v output to the ECU if you want a reading from a gauge.
Also works out cheaper than the whole Halal box and sensor. Yes you're relying on a 0-5V output and input scaling however of you add a time delay before it starts to read it isn't too bad.
There should be one spare AVI on the ECU, if not buy the Auxiliary harness which gives you an additional 4x inputs.  Just splice a 0-5 output direct to the loom and feed back the sensor ground to the wideband's sensor ground.
Then hop into ECU Manager, hit F4 and select the correct input vs. type. Once you've done that, go and adjust the linear scaling. Use what is documented in your wideband' manual. e.g 0.2V is 8afr and 4.7v is 22 (made up those numbers, they're wrong).
Then you can enable wideband feedback and engine protection too :)
Hmm, I'll head outside and look at the ecu shortly but if I were to get another WBO2 + the AUX harness it would be almost the same as getting the haltech wideband kit :(
I definitely like the idea of not having to buy the Haltech kit though - Do you recommend any particular WBO2s if I go that route?
Cheers
Bit the bullet and went with the Haltech for simplicity. Out of curiosity does anyone have recommendations for power connections? It needs constant 12V not switched - I'm not sure if it matters but it could be run to the boot where the battery is (being such a long run) or is there somewhere better?
Cheers
12 hours ago, 89CAL said:
If its closer, why not use the positive terminals in the relay box in the engine bay?
Ended up running it to the back instead, it was a straight run and probably only 1-2m longer if that.
Thanks for the help guys!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
