Yes 6262 is the cheapest single kit on there, then need more fab work to connect to cooler and dump/front pipe. Though the 3.6k price is not a BB turbo.
How much power will it make?
Much cheaper to put new wheels on both I would say.
Make some calls tomorrow.
Edited by ActionDan
He can do 64mm billet wheel but that's too big, I don't want more lag.
I'm having a chat with him about other ideas, some sort of hypergesr hybrid, but we'll see what he comes up with as I already grabbed some more -9s that came up as you don't see them anywhere near as often as 7s or 5s.
Buy my gtx3582 :P
Sorry to hear about the turbo dude.
How'd it actually fail anyhow? Being down 9kw isn't usually a sign of a completely failed turbo... seems to have only failed..... a bit?
  • Like 2
Already bought some more -9s, much cheaper and faster to just swap them in rather than have to buy new manifold and fab new intake and dump pipe (needs to go to different shop) and that's just for IWG option, which everyone here will jump up and down about it definitely needing a full TS setup the whole way through.
Edited by ActionDan
You do realize that the turbines and the "infamous twin turbo pipe" are the likely cause of the twins failing?
So throwing a billet wheel in thats gunna require being spun harder is only gunna put you back in the same scenario and faster. Poor man pays twice. Cheap out and pay for another set of turbos in another 5000km ?
Other than stealthiness there's really no reason to buy more twins nowadays. If you buy two new twins, you could buy a single + manifold/fab to fit that for the same money.
Obviously cheaper if you replace it by buying one single, but then again the real savings are in known good second hand turbos ;)
Still curious how a turbo can fail causing only a 9kw loss though? Maybe just detune the thing to 300kw and drive it around for awhile.
Able to diagnose a turbo failure without seeing it/the car/knowing the rest of the setup etc?
Where were you when I was chasing the issues that lead me to pulling it down and finding the problem. I could have used your magical diagnostic powers lol ;D
The question about the billet wheel was just that, a question, I've heard/read various shit about them so asked the question as an option. If there was an identical shweel size that was lighter and would spool faster for a few bucks more, sure I'd look at it. Can't learn about the pros and cons without having a discussion though, I think some of the people on here forget this is a forum sometimes.
Stealthiness/defect issue/RWC when selling later/cost are all factors.I am not buying new units, I found some mint ones for less than the price of 1 new one. New ones are 2400 for a pair as it is, the cheapest single kit is, what, 4k new? For a journal bearing 6262 that then needs more fab work and aooarently has shit response anyway.
Second hand manifold and single always an option, but still not as cheap as the pair of -9s I grabbed which will get me the result I wanted. To be honest, I'm tired of throwing heaps of money at it so a cheaper/faster option was desirable for me. Nobody else has to like it, it's not their car :)
Not detuning to 300kw either, crazy talk.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
