Hello boys and girls.
So the bottom end has been sorted with spool rods, Ross 9.0-1 Pistons. Air will be supplied by a GTX4294R turbo. 3x Bosch 044s will be pushing E85 fuel through 2000ID injectors. Now what to do about the head?
This will be my daily driver so I am looking at drivability over top end grunt. What Camshafts would you suggest and why?
Is it still better to go for more lift over duration or does the higher compression ratio and a bigger bottom end help lag enough that you can go 270+ duration with no major issues?
If you're really talking 1000Hp as a target, then you don't have the option of keeping the duration low.  You need revs and therefore you need cams that will support that.  So 270+ degree cams is almost a given.
There is also no reason to think that your options are "duration" OR "lift".  Realistically, you should run as much lift as you can.  The longer the duration the easier it is to get more peak lift into the lobe.  The limits are imposed by the other parts of the VT (lifter bores, springs, etc).  So whilst I won't give you a specific recommendation here, I will give you a general one that says, get something with big duration and as much lift as you can handle.
For reference, a loooong time ago I was involved in the making of a Supra do ~1000HP and it had HKS 292° cams in it (IIRC) and idled like a race bike.  Used many revs to make the power, on 98.
Contact Kelfords, they'll sort something out for it
Seems to be a universal answer these days when it comes to Camshafts and head parts in general. Cheers.
I should clear something up. I am not chasing a magical 1000awhp. I just want to max out the turbo from time to time. I am told that they are capable of that number though.
A bigger cam will definitely be required with the numbers you are seeking and the extra capacity / stroke of the 30 bottom end does address some of the low down shortcomings (debatable depending on which part of the tach you like to live in!) of throwing big cams on an RB26. I run 278 cams on my 3.4 and find they are grumpy sounding but still reasonable to drive gently due to the bigger bottom end. My compression is ~9.5:1 so its in the same ballpark as your setup but I am using twins.
You are going to need significant revs, big cams, headwork etc on that motor to get anywhere near what you are seeking so the daily drive ability is really going to come down to your definition of what is fun / acceptable to drive in traffic.
  • Like 2
Wow a 3.4l, very nice.
I know the RBs are built to rev. I know it will never drive as nice as my auto F6. But I would rather have a 900hp car that I can drive in morning traffic then brag about a piece of paper with 1000hp on it and need 6000rpm just to get the beast going of the lights.
By the sounds of things I have a very limited choice and slight more of this or that won't make much difference. Thanks for the help.
  • Like 1
The 3.4 is damn nice but a lot of work when going straight from a 2.6 and trying to keep everything looking semi stock...
To give you an idea of the effort involved with the 1000HP figure - mine pumps out an honest 450kw (just over 600HP) at the treads at 7000 revs. I have a similar fuel system to the one you are planning (A walbro 450 and 2x 044's under the car with a surge tank), ID1300 injectors, Autronic ECU and a twin GTX2867's. I could go to 8000 revs but really given how it drives now the extra stress on the bottom end just isn't worth the bragging rights. The torque is huge,  the power is nice and linear as it comes on steam and the coppermix twin clutch makes it incredibly nice to drive.
It sounds like you are in the same sort of "rather drive it than dyno it" frame of mind as me, good luck with the mods and let us know how you get on with it :)
  • Like 3
Kelford or a set of tomei I reckon will work a treat! That's gonna be a monster build and the 3.4 should give some good low down punch before that tub starts working hard.
Jeez and I'm happy with mine on -5 at 1.2 bar lol (altho it goes back soon for 1.6 and nitrous to help spool lol)
  • Like 1
Considering the "relatively low" RPM limit here which is 8000RPM, would it need a 270/280/290 degree shaft? A GTX 4294 is no GTX55 or something outrageous.
Considering it's a street car, I'd err on the side of "less is more" here if idle quality and all the rest of the things that make a nice streeter is important.
  • Like 1
Fare statement.
I am not too worried about idle. If It has to idle at a grand or more to stay happy then so be it. It's not going to be the most "streetable" daily driver but I don't want a dyno/drag queen either. So agreed. Less is more.
I am still a little staggered that we are discussing a 1000hp daily driver like its breakfast news. Not too long ago, that sort of GTR would never be considered streetable. God bless ball bearing twin scroll turbos, E85 fuel and all other things that makes this possible.
Just to clarify - and sorry if this is kind of OT, when you say "1000hp" I'm assuming you mean at the fly wheel?   A GTX4294R sits in a weird place between being arguably quite a bit too small for 1000hp @ wheels on a Dyno Dynamics, and there being much smaller/more responsive turbos that would go past that power at the crank as well.
I'm assuming that the actual aim is to run to the limit of the GTX4294R?
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
