12 hours ago, Dose Pipe Sutututu said:
Not bad at all, just need to brake later :)
Thanks man! I've had a fair few detailed tips from a few mates who are alot faster than me. So that'll give me something to work towards next time :)
Also, I had a little fiddle this afternoon and managed to get the harness bar mounted in nicely. Need to machine up a couple of new spacers to make it fit perfectly. Although it's not too bad now.
I want to run this:
1. So I can use my harnesses safely, the bar is setup to be level with the top of my shoulders. I am waiting for my other harness to arrive.
2. So I have somewhere better to mount the GoPro, so it doesn't look like I'm filming from a potato... ?
Anyway, here is a couple of photos.
  • Like 1
1 hour ago, Dose Pipe Sutututu said:
Sexy!
Are you running the same front caliper as a GTi-R?
I'm actually using A32 Maxima front calipers and rotors man.
Twin piston calipers 280mm rotors.
Rears are a mash-up
Essentially A32 Maxima setup
Although on an N14 its not a plug and play unlike an N15.
GTiR rear calipers with A32 Maxima caliper brackets and Ford Focus ST170 rear rotors (280mm) machined down to 278mm same as the Maxima.
GTiR rear calipers are the same physical caliper as the A32 rear, just the caliper bracket spacers the caliper out.
21 hours ago, Dose Pipe Sutututu said:
Interesting! That's pretty cool man!
If you get a bit more competitive I reckon have a chat to Intima Brakes Australia, they love sponsoring grass root motorsports!
I want to keep this car street registered or at least right on the border lol, hence no cage, so no full on serious racing for me.
I will have a shitload of fun doing some 'club' type track days in it though, especially with the wife on board with it all ;)
Alright guys, another parts accumulation post.
I bought myself a 4 point underbody brace from Whiteline, I'll fit it up and re-wheel align before the next track day :)
P.S
I've got a bigger post coming, it's more parts accumulation, although I think you'll like it.
Okay, another update. I have had this in my hands for some time now, although I haven't posted any images just yet, so here they are:
This is a SR16VE N1 intake manifold off the JN15 VZR N1.
These intake manifolds have a larger throttle body and better designed runners than the SR20VE, their only downfall is they are designed for a 1.6L, so the diameter of the runners is a little small.
I sent the manifold over the AMMFAB in the US as his work is second to none, especially his welding on cast aluminium.
The runners were ported out excessively, same as the plenum. This is the intake manifold I plan on running on my built 20VE once finished.
The N1 manifold have been proven in the past once ported to within an inch of their life. So I am hoping this one will be the same.
The plan is to have the manifold and TB ceramic coated in silver to keep it looking nice and bright.
Enough jabbering and time for some photos:
Edited by TimmyMA70
  • Like 3
3 hours ago, Jordy32 said:
Oh wow, you're not kidding about it being ported to within an inch of it's life
Definitely don't kid, lol. I'm really keen to see how it performs though!
2 hours ago, Ben C34 said:
That's some nice work.
Thanks Ben, hopefully the work pays off mate.
Wow, amazing!
Can't imagine that being more cost effective than a tank of nitrous but hell cool!
?? she's always going to be strictly N/A, no swaying me there matey.
Definitely won't be as cost effective though, you're right.
16 minutes ago, WantGTR said:
So much this. Gassed my pulsar way back on my Ps. Dollar/hp cant be beaten.
I really love an unassisted N/A screamer ?
Unfortunately $/hp sucks quiet alot in that respect. That's why I put the N14 on a diet ?
  • Like 1
Gas is just like the icing on the cake. A single fogger wet system is easy and cheap to setup.
You can still have a crisp AF na screamer.... with an ace up your sleeve ?
Having an n14 before i regularly check this thread lol
Edited by WantGTR
  • Haha 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
