37 minutes ago, WantGTR said:
Gas is just like the icing on the cake. A single fogger wet system is easy and cheap to setup.
You can still have a crisp AF na screamer.... with an ace up your sleeve ?
Having an n14 before i regularly check this thread lol
You're more lebo than I thought haha
it made 50% more power for $1400. cant beat that. Thats nitrous kit (NOS brand), 1st bottle fill, different spark plugs, bit of dyno time for correct jetting.
That intake manifold definitely won't double my power, that's for sure haha!
So $/kw NOS is still the winner.
However when the engine is finished I am hoping that this little N/A screamer will make your pee pee move ?
Hey guys, another update.
My Ross Performance Crank trigger + pulley has shown up!!
AFAIK this is the first one of their production ones to be sold ?
I'll let the pictures do the talking though.
  • Like 1
  • 1 month later...
Hey guys, have been a little light on updates the past couple of weeks.
Although did another track day on the 12.8.18
A touch slower partially due to track temp being only 7°C at 2:30pm very cold day, and I had come down with the flu, (was still going to drive though!)
Anyway, as always, enjoy and be gentle ?
  • Like 1
I like that crank pulley, very nice. Any idea on where/how you are going to mount the sensor?
That was the problem for me, nowhere to mount it reliably. If my "homemade crank trigger" off the flywheel fails, i might copy what road you take
  • 1 month later...
  • 4 weeks later...
On 10/17/2018 at 1:09 AM, 180sxnit said:
Any more updates?
Heaps of updates mate!
I've been spending more time at the track than I have updating my build threads ?
I'll do another big update soon, thanks for asking :)
  • Like 2
  • 2 months later...
Found this thread while searching for brake upgrade ideas and got hooked.
Love the progress you've made with the car thus far!
quick question though:
Why did you use n16 hubs for the a32 discs and calipers? and which model n16 were these hubs sourced from?
  • 1 month later...
Hey mate, I haven't been on the forum much lately.
However, I'm back ;)
I used N16 hubs as the hole centers for the caliper carrier bracket are the same as A32 Maxima :)
Saves making a dogbone to mount the caliper.
  • Thanks 1
Alright guys, prepare yourselves for a big update session
A quick snap of how the car currently sits:
I scored myself a brand new genuine 90A alternator from a P12 SR20VE Primera :)
There is a reason for the want of extra amperage alternator in a later post ;)
A Pulsar Group of Aus member was making up these radiator panels, so I jumped on it, for the price of it, I couldn't even buy the material to make it!
All painted up and refitted:
Started aquiring some parts for the P11 SR20VE again:
Water Pump blanking plate:
I made a discovery a few years ago that the RWD GKTech water temp sender 'blocks' will suit a FWD setup if you cut off the extended leg
A Davis Craig EWP kit, doing away with the crank driven water pump (NA LIFE, lol)
Since I'm removing the crank driven W/P I though I'd continue the theme and went for a Holden Astra P/S pump, the price was very good, hence buying 2 of them.
Edited by TimmyMA70
A set of 16x7 +35 Buddyclub P1's came up for sale, and I just had to have them (track wheels)
More part hoarding:
Oil filter block, removes the oil filter housing
I have a couple of 32V (V for Viscous LSD) Gearboxes. The one in the car currently is out of a JN15 VZR, it has really short 1st - 3rd gear, 4.43:1 FD. Really fun behind a SR20DE, although the gearing behind a SR20VE isn't ideal, it has you dropping out of VVL.
This gearbox is out of a FN15 Autech, which uses a 4.4 FD although the same gearing as what out locally delivered N14/15 manuals, which is a nice spread.
The advantage of the 32V series is Cusco made a mechanical 1/1.5way LSD for them :)
Nismo did do a Mech LSD for the 32A (Aus delivered non LSD gearbox) however with the APRA series, they've all been snapped up and are NLA
This 32V is in dire need of a good clean-up:
BEFORE
AFTER
Edited by TimmyMA70
  • Like 1
I've always loved the P12 SR20VE valve covers, however they are deceivingly 'deep'. Using the OEM oil filler cap just looks way too small.
This Nismo one popped up, it is ratchet too which I liked.
I'm probably going to paint it, although its a better option :)
I made another discovery that early SR16VE used a water pump gasket. The later SR's have grooves in the sealing face to be able to just squeeze liquid gasket into. This is all well and good, however my water pump blanking plate is indeed just flat, no grooves for liquid gasket:
Again with the parts hoarding...
P11 and P12 Xcessive Manufacturing Thermal intake gaskets
Why the P12 one you ask??
You shall see :)
Edited by TimmyMA70
Okay, now to answer the P12 questions:
Confirmed 90,882kms from JP
She isn't pretty, although give me some time!
Test fitted the 4-1's
Clearance is clearance ;)
Then... Found that the head gasket was about to weep oil:
Top end looks clean:
Things escalated:
Started the clean-up:
  • Like 2
Continuation of 'let the cleaning begin'
BEFORE
Oil pump was stripped down, all machined surfaces were taped before being cleaned.
AFTER
BEFORE
AFTER
Upper runners and Plenum:
BEFORE
AFTER
Lower Runners
BEFORE
AFTER
Starting the reassembly
Getting there now!!
Edited by TimmyMA70
Cleaned the carbon out of the ports on the head and the combustion chamber, also blued the valves and valve seat to check sealing before reassembly
New valve stem seals and installation tool
Reassembled and ready to be bolted on
Head bolted down with new OEM P12 MLS head gasket, new headbolts and washers.
Rocker gear in!
Cams in
Checked Valve Clearance, pretty damn good really.
Although, I've put an order in to change a heap of the shims out to get spot on OEM valve clearance.
BqYe9RE.jpg?1
Onto the next project...
As you saw in earlier photos the Valve Cover was in dire need of some love.
Paint Stripped:
Rubbed by hand to remove all corrosion:
Masked, ready for painting:
Paint time:
Bake time:
Edited by TimmyMA70
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
