15 minutes ago, ActionDan said:
MIG, oh and it needs a gun apparently.
A mate who welds said its "a pretty good welder".
I was going to just do the buy a cylinder from bunnings thing.
Mig is pretty good, quiet universal and somewhat easy to use, the hardest thing is setting them up. Most guys just set them up by the sound.
Yeah perfect. They don't offer the 'trade - n - go gas' at my local Bunnings, so Gasweld/Sydney tools are the go-to for me.
  • Like 1
On 17/11/2019 at 8:14 PM, iruvyouskyrine said:
I hear this may be making its way to Newcastle in the next couple of weeks, is that correct?
I am from Newcastle ?
On 17/11/2019 at 8:35 PM, Dose Pipe Sutututu said:
Out of all the builds, all the hectic inshallah GT-R builds, this is still my favourite build
Hahahah!!! Thanks so much man! That means more than you can imagine actually dude. Especially with all the awesome GTR's on here!!
On 18/11/2019 at 8:17 AM, ActionDan said:
Do people still build GT-Rs on here?!
? Hmmm. Not sure! Apparently Pulsar > GTR ??
Since the car has been off the road for so long, the brake rotors had began rust. So gave them some love in the bead blaster and scuffed the brake pads up (figure 8's on a sheet of 80 grit)
Flushed and bled all the brakes, for good measure.
It's getting alot closer to driving it now!
19 minutes ago, ActionDan said:
I've had good success scuffing pads before, same pricess pretty much.
How far away is your tuners dyno?
Yeah it's worked quiet well, spoiler alert... the car is currently driving ?
I've been slack updating this.
Untuned, however AFR's look excellent. Haven't given it a decent rev, obviously, however I'd be happy to cruise on the highway with it. Drives surprisingly well for a map, which isn't even 'SR20 Specific'
The dyno is less than 100kms from me.
Had to slightly modify the front cross member to allow extra clearance for the 4-1 headers.
After that, finally drove the thing!!
Obviously light load, watching AFR's like a hawk.
Drove it down to a mates shop where I did a wheel alignment.. for the street. For now..
  • Like 1
17 hours ago, niZmO_Man said:
That is a nice exhaust, along with the rest of the car
Thank you very much! The outside of the car definitely isn't the best. However that's never been my strong suit either.
I'm planning to have a small amount of paint and panel done in the new year, although I'm not going all out, as the car will be used, not a trailer queen / garage ornament.
12 hours ago, ActionDan said:
Looking good.
Slightly more rear camber? Is that a FWD thing?
Engine bay looks mint.
Basically it helps the rear end hang on through a corner, prevent the back end over taking the front lol.
Thanks man!!!
Update: car is at the tuners now
And a Skyline for all you SAU Junkies 20191202_153734.thumb.jpg.451e0f2a02b6e6b004e48f68ade342a6.jpg
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
