15 minutes ago, ActionDan said:
MIG, oh and it needs a gun apparently.
A mate who welds said its "a pretty good welder".
I was going to just do the buy a cylinder from bunnings thing.
Mig is pretty good, quiet universal and somewhat easy to use, the hardest thing is setting them up. Most guys just set them up by the sound.
Yeah perfect. They don't offer the 'trade - n - go gas' at my local Bunnings, so Gasweld/Sydney tools are the go-to for me.
  • Like 1
On 17/11/2019 at 8:14 PM, iruvyouskyrine said:
I hear this may be making its way to Newcastle in the next couple of weeks, is that correct?
I am from Newcastle ?
On 17/11/2019 at 8:35 PM, Dose Pipe Sutututu said:
Out of all the builds, all the hectic inshallah GT-R builds, this is still my favourite build
Hahahah!!! Thanks so much man! That means more than you can imagine actually dude. Especially with all the awesome GTR's on here!!
On 18/11/2019 at 8:17 AM, ActionDan said:
Do people still build GT-Rs on here?!
? Hmmm. Not sure! Apparently Pulsar > GTR ??
Since the car has been off the road for so long, the brake rotors had began rust. So gave them some love in the bead blaster and scuffed the brake pads up (figure 8's on a sheet of 80 grit)
Flushed and bled all the brakes, for good measure.
It's getting alot closer to driving it now!
19 minutes ago, ActionDan said:
I've had good success scuffing pads before, same pricess pretty much.
How far away is your tuners dyno?
Yeah it's worked quiet well, spoiler alert... the car is currently driving ?
I've been slack updating this.
Untuned, however AFR's look excellent. Haven't given it a decent rev, obviously, however I'd be happy to cruise on the highway with it. Drives surprisingly well for a map, which isn't even 'SR20 Specific'
The dyno is less than 100kms from me.
Had to slightly modify the front cross member to allow extra clearance for the 4-1 headers.
After that, finally drove the thing!!
Obviously light load, watching AFR's like a hawk.
Drove it down to a mates shop where I did a wheel alignment.. for the street. For now..
  • Like 1
17 hours ago, niZmO_Man said:
That is a nice exhaust, along with the rest of the car
Thank you very much! The outside of the car definitely isn't the best. However that's never been my strong suit either.
I'm planning to have a small amount of paint and panel done in the new year, although I'm not going all out, as the car will be used, not a trailer queen / garage ornament.
12 hours ago, ActionDan said:
Looking good.
Slightly more rear camber? Is that a FWD thing?
Engine bay looks mint.
Basically it helps the rear end hang on through a corner, prevent the back end over taking the front lol.
Thanks man!!!
Update: car is at the tuners now
And a Skyline for all you SAU Junkies 20191202_153734.thumb.jpg.451e0f2a02b6e6b004e48f68ade342a6.jpg
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
