Exedy Twin Disc Install/Help
I just recently purchased an Exedy Twin Disc clutch for my GTR R33 (RB26), and I'm currently in the process of installing it. However, after pulling the tranny, ran into a bit of a problem. The transmission and engine won't mate back together because the fork(pull type) and the output shaft sleeve on the transmission won't let it slip all the way back together( there is about 3/4 inch gap between trans and engine). I was told something about machining the sleeve down a bit, however my local car shop that deals quite a bit with JDM cars, they said it should just bolt right up. At this point I would love some help from the experts here, any ideas on what to do, or has anyone else run into a similar problem? If any more information about the car or clutch is required, just say so, first post here! Car is a 1996 Nissan Skyline GT-R R33 VSpec, clutch is an Exedy Carbon Twin Disc with a lightweight flywheel. Thanks for reading!
https://www.sau.com.au/forums/topic/470448-exedy-twin-disc-installhelp/
24 minutes ago, nicholas_ti07 said:
Im not sure, how does one align a twin disc properly?
there is a clutch alignment tool available, sometimes they come with the clutch kit. it is shaped like the input shaft and keeps the clutch in precisely the right spot when fitting it.
Oh yeah that much Ive done, it's just the fact that the output shaft coming out of the trans, it slides into the splines on the clutch just fine, but it hits that mid plate thats between the two clutch discs, and the clutch fork is also hitting something, done so much research and apparently no one knows whats happening lol
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
