Wrecked R34 GTT HTA3076 twin scroll rebuilt gearbox E85 fuel setup
R34 GTT wreck
Car has a lot of great parts on it with very low klms
HTA3076 with Sinco twin scroll manifold and two turbosmart external gates along with screamer pipes and dump - fitted may 2016 (Amazing turbo, Total cost $5000+ Had to buy the turbo then get the twin scroll housing separately from GCG then get screamer pipes and dump made up)
rebuilt rb25 gearbox (have receipt for $3800 from last year - very low klms)
Big fuel set up - ID1600cc injectors, 1000hp external fuel pump, surge tank - all suited for E85 (Injectors were $1200 by themselves)
power fc
ARP head stud kit, Nitto head gasket, Tomei type B cams, performance valve spings - fitted august 2016
Greddy radiator
Wilwood big front brakes (I believe around 350mm? - require an 18" wheel minimum)
RB25 Neo internally standard
Those are the parts I can think of right now.
My preference is to sell the whole car as is. This is due to the fact that I fractured my humerus in the crash, otherwise I would part it out. If I cannot sell it whole, I will store the car for a while until my arm gets better and take all the parts off and sell them separately.
Asking $8000 which I think is a pretty good deal when you consider just the cost of the turbo kit and gearbox were actually higher than this by themselves.
Edited by vkadam
  • Like 1
On 13/06/2017 at 6:56 PM, ERO54N said:
Fk dood, you ok?
Yea not too bad Thanks
On 13/06/2017 at 9:15 PM, Anonymouse said:
banged up good - car and you
Want to tell us what happened?
Impound yard?
Not impounded just at the crash investigation centre.
On 15/06/2017 at 0:51 PM, B-rice said:
I live in Canberra and interested in some parts. Provided if you allow me to remove myself
Which parts are you interested in? I was trying to sell the wreck whole, however the bigger the item and the more $$$ I can recoup, the more I would be interested in separating parts out.
On 16/06/2017 at 5:07 PM, ozzydee said:
Hows the condition of the rubbers around driver and passenger window ???
Were fine before the crash.
On 16/06/2017 at 10:39 PM, DJBarnstar said:
Can I buy the Taser?
I will ask old mate next time I am over at AFP.
Hey guys
Thanks for the inquiries and PMs. I am still at this stage trying to sell the whole car as one. However if it does not sell after a few more weeks I will get back to everyone with prices of individual items.
Regards
Adam
Hi mate if you decide to part out I'd be interested in the following
Engine wiring loom
Fuel pump
Possibly coilovers and E85 setup
Could come check out for more stuff potentially.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
