S15 vs Evo 7-9 Track Car
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Lol equating brand differentiation with bravery is a new one lol.
Hatches look fugly as, personal preference. A Renault will have substantially less local support in terms of parts/knowledge and likely cost more to mod.
It seemingly offers no advantage over lots of other suggestions besides "bravery" and we don't mesure that at track days lol
Considering S15/14 due to my Nissan knowldge and affiliation (2x GTRs 1x Skyline and 1x Silvia). Parts availability and price. Plenty to choose from. Better suspension and chassis than my S13 which still needs 5 stud and a proper cage and is a tired older car with an original motor and box. Oh and RWD (less understeer issues apparently) and weight advantage over Evo.
I just need someone to throw me the keys to their Evo so I can go see what I think of it on the limit of grip.
In that case, you'd best stick to what you've got and continue driving it.
By brave I mean, live your life and buy something wild seeing you've already mentioned you've got a daily and 2 other cars, I'm sure you can afford to wait for parts to arrive etc whether it's a fugly hatch or a evo that you've been trying not to buy, we all know you've babbled on about evos so much of late.
Just buy a evo already and close the thread.
  • Like 1
Can I put in a vote for more track time???
I got held up by a douche in an evo once, obviously his first track day but still, had way more power than me (stockish R33) so he'd pin it on the straight, couldn't catch up, then by 2 corners he was holding me up again.
Selling 34 is an option.
Makes more sense to have a better track car where I can actually enjoy the speed safely and legally.
You guys make me laugh, discussion seems to upset you, but you still participate? Sadists?
Has been some good info for me from a few of you so thanks for that.
I always enjoy the salt too lol
#bravery #discussionfreezone
Caterham. Your missus and kids will love the wind through their hair... Except have to be one passenger at a time.
Will feel fast without breaking the speed limits! Motorkhana and hill climb safe! Ford engine mods are plentiful! Registerable open wheeler! Be the envy of all your golf mates!
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
