S15 vs Evo 7-9 Track Car
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Lol equating brand differentiation with bravery is a new one lol.
Hatches look fugly as, personal preference. A Renault will have substantially less local support in terms of parts/knowledge and likely cost more to mod.
It seemingly offers no advantage over lots of other suggestions besides "bravery" and we don't mesure that at track days lol
Considering S15/14 due to my Nissan knowldge and affiliation (2x GTRs 1x Skyline and 1x Silvia). Parts availability and price. Plenty to choose from. Better suspension and chassis than my S13 which still needs 5 stud and a proper cage and is a tired older car with an original motor and box. Oh and RWD (less understeer issues apparently) and weight advantage over Evo.
I just need someone to throw me the keys to their Evo so I can go see what I think of it on the limit of grip.
In that case, you'd best stick to what you've got and continue driving it.
By brave I mean, live your life and buy something wild seeing you've already mentioned you've got a daily and 2 other cars, I'm sure you can afford to wait for parts to arrive etc whether it's a fugly hatch or a evo that you've been trying not to buy, we all know you've babbled on about evos so much of late.
Just buy a evo already and close the thread.
  • Like 1
Can I put in a vote for more track time???
I got held up by a douche in an evo once, obviously his first track day but still, had way more power than me (stockish R33) so he'd pin it on the straight, couldn't catch up, then by 2 corners he was holding me up again.
Selling 34 is an option.
Makes more sense to have a better track car where I can actually enjoy the speed safely and legally.
You guys make me laugh, discussion seems to upset you, but you still participate? Sadists?
Has been some good info for me from a few of you so thanks for that.
I always enjoy the salt too lol
#bravery #discussionfreezone
Caterham. Your missus and kids will love the wind through their hair... Except have to be one passenger at a time.
Will feel fast without breaking the speed limits! Motorkhana and hill climb safe! Ford engine mods are plentiful! Registerable open wheeler! Be the envy of all your golf mates!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
