Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
  • Like 2
Not much of an update but painted N1 vents and parking stick thingo.
Also cut out the middle of the bumper to suit the new plates and gain more airflow as these like to run hot.
  • Like 1
Don't like how big and bulky the airbox is and the stupid sound suppression part that just collects sand!
Started off like this
Chopped it in half and then I was left with this nice flat surface to adhere the new mounting section to.
Also noticed that the round section actually sits outside the chassis rail in the wheel arch, so incorporated a cold air intake port into the new piece.
  • Like 2
Finished re-sleeving the whole harness tonight finally. What a mission but I think the outcome will pay off with a much neater engine bay. All I need to do is buy some larger clear heat shrink so I can branch the connectors off to where they need to go.
I won't tee it all off though until its on the engine as I might be able to re route some it to further neaten it up.
Not Rywire or Chase bays spec but gives it that little extra professionalism.
Got the turbo back from getting rebuilt by MTQ as well. Shaft and cartridge journals were scored, some bent turbine fins and a small crack in the rear housing.
The rod bearings are going to be here until January now, so when I get back from Holidays it's go, go, go!
Edited by Sack87
  • Like 2
  • 3 weeks later...
I got the engine to a stage where I could bolt the gearbox back on and drop it on the subframe. I can easily roll it all out for the remaining work to do on it for ease of access.
Had more delays in timing chains not being in stock locally and having to get them from Japan again and they won't be here until next weekend. Have some small bits coming from over East too which were supposed to be here by Friday but not coming until next Thursday, otherwise I would have bolted the whole lot back in the car.
  • Like 2
Engine harness is all but done. A few little brackets to be made and two more connectors needed. It's 10x neater than what it was.
Injector harness is almost fully tucked.
Degreased the engine bay as I'm 95% ready to bolt the engine up to the body. Someone else has already been in here before me.
  • Like 1
Can you tell us what you had done to the turbo? Looks like a bigger compressor wheel... steel/inconel turbine? Cost? Expected power? So many questions... :)
Looking good by the way!
Edited by andynogo
It's a Billet Intense RS I bought from Scotty a few years ago. You'll find heaps of info on it in the turbo upgrade thread, but good for 500hp he says.
  • Like 1
Very good- should make some decent power!
On 1/28/2019 at 7:53 PM, Akshunhiro said:
Looks like someone had the joy of swapping out the turbo!
Yep. Everything has silicone on it to seal it up, including water hoses onto pipes. I bought a dud...
Got it bolted back this afternoon after doing heaps of little things around the engine that are hard to get to when it's bolted in.
Still heaps of fiddly little shit to go though
  • Like 5
  • 3 weeks later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
