Yeah same for mains.
You can buy single pistons from Nissan, which I did to replace number 6 and bought another set of rings. All the bores got honed so it's fresh again.
They're both headache savers but Amamaya's processing time is a bit slow. Everything is in Australia for this order yet it takes 3 weeks to get it.
Hey mate, was just wondering what grade bearings came out of your engine?, connecting rods and mains. I had grade 0 across the board. I was expecting to see graded bearings in there to match the blocks crank bore and crank journal and pin journal size stampings. Did you just replace with same grade bearings that came out or get the micrometers on it? Cheers
Pretty sure mine were grade 0 too. I just put what came out back in and all the clearances came up spot on.
  • Like 1
Finished off Deutsch plugging the engine harness. If I decide to change ECUs down the track, all I have to do is Deutsch plug that harness.
It turned out bulkier than I would have liked but it will be tucked away behind the glove box.
  • Like 2
Oooh 3k! Should be interesting to see what the normal driving is like. Should be pretty ors for the drag strip! They've got expensive though ... Must be a long time since I've checked the prices! Sigh. Another thing to add to the budget... :)
Pulled out the nav unit to make way for the EMU. Made up a bracket/fascia to house it and have two provisions for the option harnesses. I still need to wire in the LC2 and mount the unit but that can be done after run in.
  • Like 7
  • 4 weeks later...
Fitted a Raceworks 340lph fuel pump and wired it with direct 12v feed. You can't even hear the thing ?
FYI, on M35 Facebook book page and Matt's photos, there must be a slight change to the pump since 2016 as it didn't go all the way into the filter. With all my body weight on it and with silicone spray, that is as far as it would go in. Can't run the rubber damper as it would not ever fit. It's not coming though as I modified the base so it cups the end of the pump.
(I did have the base on the wrong way in the pic!)
  • 3 weeks later...
Got the turbo back and they said they found nothing. They said it was either too much oil supply or not draining enough.
I asked what pressure they test them to and they said their machine does 60psi max. When I said these engine do up to 120psi and I had drilled the restrictor out, he said that will will most definitely make it leak as its way too much for even the wider seal they put in there to handle it.
Burred out my drain as big as I could and under their advice, bought a Turbosmart Oil Pressure Regulator (OPR) These are made to only allow 40spi into the core but at maximum flow.
Only place it could go is in the cam cover as it needs a drain. Drilled a hole just below the filler and inserted a tight fitting grommet. Ran new lines and it seems to be all sweet for now.
  • Like 2
  • 1 month later...
Got around to welding in another muffler, 100 cell cat and O2 bung.
Car did not get any quieter which I had hoped for because I have another piece to weld on when I get it to make it louder!
  • Like 2
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
