39 minutes ago, iruvyouskyrine said:
All Americans should read this thread before considering buying a GTR. It's funny seeing people learning things that we have known for 15 years.
PS, driving a standard GTR below 5k and never pushing it sounds very boring
OP is in Canada and they began importing 10 years before US.  But I think most people are surprised by how little of a history comes with each imported car, a car could have been driven to the ground but claimed to be a grade 3.5 auction car.  And then they are surprised by how old these cars actually are, freshly arrived at dock and bam everything broke after a week.
Mine came from UK and fully serviced including timing belt before being exported.  After I got my car I decided to have timing belt replaced anyway because for some reason they didn't replace water pump.  And then behold the f*ckery, open the timing cover to see a brand new timing belt with rusted factory tensioner pulley.  You will be surprised how many sh*t cars we get because of shady exporters/importers/middle men.
Almost defeats the purpose of the GT-R :P
Also, stock turbos vs. N1 turbos, massive difference and a good incentive to get rid of the stock ceramic turbos ASAP.
I'll eventually surely get used to the stiff clutch... If I could of driven it more then 6 times this summer before it broke down. Lack of time, shit weather and the breakdown made me drive it less then 500km. I'm learning stick on that car.
As for being boring for driving under 5k, nah it sin't boring when you're used to driving a n/a auto bimmer. The GTR is my first ever turbo car, just hearing the turbos spool is all I need :6_smile:
1 hour ago, niZmO_Man said:
Good thing about the GT-R clutch is the high friction point, I only press my clutch half way down at most (super duper heavy clutch).
Oh yeah, same on mine, friction is a bit before the center of the peddle travel. Makes changing gears easy. Haven't driven it enough to know exactly where the perfect position is so I just declutch rapidly until I feel a bit of a bite then give it some gas then fully declutch. Makes me not jerk the car at all.
  • 11 months later...
I'm backkkkkkkkk! 10k$ later.
Finally it works and it got tuned at 356rwhp at 15psi. Boooya.
Ends up I don't stock turbos cause first dyno pull got me 429rwhp in 3rd gear at 25psi lol (manual boost controller was stuck in wide open position)
if anybody is interested in the whole year of nonsense with this car I can share.
  • Like 1
Sounds like you went on a learning sabbatical.
Lay the experience on us, with pics.
7 hours ago, Dose Pipe Sutututu said:
Should have run it in 4th, not 3rd
3rd gear was for a feeler at first
Yeah i can do that, but I don't have many pics since it was at the shop and I've been way busy working.
Oh boy here we go.
So let's pick it up where this thread ended.
Summer 2017 : The oil pressure dropped drastically on my way to the tuner. Tuner checked the oil pressure sensor and gauge and everything was working fine. Basically confirming that oil pump failed. It didn't crack or anything but failed to deliver a satisfying oil pressure.
End of summer 2017 : I decided to not get the block rebuild or even opened. I'm confident I didn't need to since the oil pump failed just before I got to the tuner. I never beat on the car and always took great care of it so I didn't see any point. Engine going to come out for new oil pump sowhile I'm at it I decided to buy a few other maintenance things. Car also got towed to a guy I know that works a bit on skylines.
- New N1 oil pump, New OEM water pump, New timing belt and pully kit, and some new door window trim.
1232311564_oilpump.thumb.jpg.d80f3b015fdfbd5e2c2ea4f79edf5c9e.jpgwindow_felt.thumb.jpg.522082ab94e4f153b0b3ecd5edc46251.jpg
Winter 2017/2018 : Engine got removed. All new parts got put back in. I also remebered that the power steering pump was leaking quite badly so I ordered a new set of steering pump seals online.
Old oil pump. Don't know what caused it to fail.
Winter 2018 : Guy I know was about to finish putting everything on the engine when he got hit by the oil pan. No clue how he managed that but it hit his eye pretty badly. Had to get it eye removed and replaced by a glass one. At least it wasn't his good eye, he already had lost 100% of his vision in that eye from an old accident he got in his youth. This obviously caused some delays.
June : Got the car back. As I was driving it back home there was some odd metal grinding noise that I could faintly hear. I droped the car off at a mechanic specialised in JDM cars really close to where I live. funny thing is, it's my mom that found the garage. Out of all people! Anyways, talked to the dude at the garage  and ends up he's from New Zealand and worked on import cars over there. He checked the car out fearing it was the front diff that was making the grinding noise he got it on a lift. and well, let the nonsense begin.
Front and rear cambers arms were shot. Coilovers didn't have the locking retainers things, I had no rear subframe bushings, they were like rubber floor mats it looked like, an ATESSA oil leak, HICAS was fully removed, but no lock out bar was there. I thought I had HICAS but turns out it was just the rear wheels doing whatever the F they wanted. At least the front diff was fine, it was just the front wheel holding on by only one bolt. Coulda lost the damn wheel! Weird is I didn't feel it in the steering at all.
Seeing how messed up the underside of the car was I asked him to take a look inside the engine bay. I've never seen a mechanic so confused  before but turns out it's a KA24E rad I had inside the car and not an RB26 one (For you aussies out there, in Canada/USA the 180sx/silvia are called 240sx and they had a shitty 2.4L truck engine making like 150hp inside of them rather then the sweet sr20det). So the car needed a lot of work done to it, so I left it there.
June/July : Unfortunatly I don't have any pictures because I was gone for 1.5months for work while the car was being fixed. Here are all the things that got done to the car.
- ATESSA oil leak fixed. I was just a gasket.
- Headlights finally worked properly. New wiring was done.
- Got a horn installed because it didn't have one. 240sx horn FTW!.
- Inhouse custom rb26 rad. It's legit 4 times wider then the other one I had in the car.
- Front and rear camber arms replaced by non Ebay shit.
- New brakes all around
- Removed the vent to atmosphere BOV and got it back to factory recirculating one.
- Fully refreshed rear diff. (it was welded before)
- Brand new Tein fully adjustable Street Z  coilovers on all 4 corners. It's so comfy now, I love it.
- Got 1 MAF changed.
- Probably forgetting some other stuff, but can't remeber everything.
August : The car drove so much better then before but still burnt stupid rich so it was time to get it tuned. Busy with work, I wasn't able to go to the tuner myself so I got the JDM expert guy to get it tuned for me. Which was a really good idea before theres even more confusing shit in this car. To list a few :
- Jammed in wide open position boost controller. Car ran at 25psi on the first dyno pull... on what we thought was stock turbos.
- Ends up I have a RB20DET computer inside the rb26 computer case. Been told the tuner was confused AF when nothing he was trying to tweak was working. Ends up 1MAF was completely ignored. Got it changed to a rb26 computer.
- A bunch of vacuum lines had to be redone.
- On the plus side, ends up I have GT2860-5 turbos in the car and a really healthy rb26 that shows signs of a full rebuild/refresh not too long ago.
So all in all the car is almost completely done and is supposed to drive like a dream. I'll see for myself today, I'm picking the car up this afternoon.
There are still a few things expensive things to get fixed next year, but for now it's enough.
So all in all this car is an expensive pain in the arse but I love it and should like it even more now that it's fully tuned.
CHEERS!
Edited by drunken0elf
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
