What is the power range you want, and your setup etc?  It's hard for anyone to tell you which is better suited when you've mentioned two turbos which flow different to each other.  I'm personally not a huge fan of either in the current market, much better options for what both can do out there now.
The power range id like, would be around 350kw and at the moment the upgrades are, 750cc injectors, link G4 ecu, front facing plenum, 6 boost manifold and so forth, if there is a better turbo that is more suited for the type of set up I’m after, which would be more street but occasionally track.
Edited by Fr3akyR33
Ah that makes life simpler.  On 98 octane?   I can say straight out, a GT4088R is overkill for that power... though these days a GT4088R is pretty much pointless in every way unless you are pretty much given it.
Edited by Lithium
  • Like 2
For simplicity go internal.
External means you'll need a new manifold, dump pipe, wastegate, plumbing so on and so forth.  To go drive in drive out with a new external gated turbo you're probably talking $6k including turbo.  To do it internal you're looking at half that including turbo. (That's JUST to buy the turbo and have it fitted - NOTHING ELSE)
Note, you're going to need a hell of a lot more than just a turbo to hit your power goal.
350kw is going to be a $10k-$15k spend.
Turbo
Cooler
Injectors
ECU
Exhaust
Coilpacks
Clutch
AFM
Filter
Fuel pump
Fitting parts
Tuning
I suggest you stop worrying about specifics, ie. which turbo, and spend the next 6 months reading and researching these forums as to what you're getting yourself into.  It's clear you have absolutely no idea so you need to research like a madman.
Start researching for a well regarded workshop near you who you will get to do the actual work and then work with them, as well as what you can learn here, and start buying all the pieces you'll need to complete the jigsaw (after lots of research).  If you rush into it and start hanging all sorts of random shit off your engine, you'll end up spending $25k and you'll get a shit outcome.  Research, patience and knowledge is your friend.
Seriously for what you want just shove a gtx3071, a good exhaust and intake, a good cooler, a fuel system to feed and an ecu to control it and a clutch to hold it
and if it's a 33 engine save some money for a bottom end cause it'll hurt a rod eventually
  • Like 1
  • Thanks 1
If it is purely for street use and not used in a competitive motorsports environment, then 300kW is plenty for a car with basic suspension modifications (i.e. a set of coilovers) and the factory LSD.
270~300kW is very achievable with a small budget and will be "fast" enough and "fun" enough.
Once you start go to beyond that, expenditure increases exponentially where as before that it is linear some what lol.
Hypergear ATRG3SAT would easily do that on 98RON and give you a bit of headroom in future if you ever decide to spray some WMI or go E85.
Another question before you start throwing out turbo makes/models etc. is when you want the turbo to come? yes any big turbo can "make" the numbers you want but when is another question?
No point slapping a biggish turbo on your car to make only 300kW and have it come on late - very american mentality. "oh be dayem, it makes 500hp on a mustang dyno, and I dont' mind the lag because I'm american"
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
