What is the power range you want, and your setup etc?  It's hard for anyone to tell you which is better suited when you've mentioned two turbos which flow different to each other.  I'm personally not a huge fan of either in the current market, much better options for what both can do out there now.
The power range id like, would be around 350kw and at the moment the upgrades are, 750cc injectors, link G4 ecu, front facing plenum, 6 boost manifold and so forth, if there is a better turbo that is more suited for the type of set up I’m after, which would be more street but occasionally track.
Edited by Fr3akyR33
Ah that makes life simpler.  On 98 octane?   I can say straight out, a GT4088R is overkill for that power... though these days a GT4088R is pretty much pointless in every way unless you are pretty much given it.
Edited by Lithium
  • Like 2
For simplicity go internal.
External means you'll need a new manifold, dump pipe, wastegate, plumbing so on and so forth.  To go drive in drive out with a new external gated turbo you're probably talking $6k including turbo.  To do it internal you're looking at half that including turbo. (That's JUST to buy the turbo and have it fitted - NOTHING ELSE)
Note, you're going to need a hell of a lot more than just a turbo to hit your power goal.
350kw is going to be a $10k-$15k spend.
Turbo
Cooler
Injectors
ECU
Exhaust
Coilpacks
Clutch
AFM
Filter
Fuel pump
Fitting parts
Tuning
I suggest you stop worrying about specifics, ie. which turbo, and spend the next 6 months reading and researching these forums as to what you're getting yourself into.  It's clear you have absolutely no idea so you need to research like a madman.
Start researching for a well regarded workshop near you who you will get to do the actual work and then work with them, as well as what you can learn here, and start buying all the pieces you'll need to complete the jigsaw (after lots of research).  If you rush into it and start hanging all sorts of random shit off your engine, you'll end up spending $25k and you'll get a shit outcome.  Research, patience and knowledge is your friend.
Seriously for what you want just shove a gtx3071, a good exhaust and intake, a good cooler, a fuel system to feed and an ecu to control it and a clutch to hold it
and if it's a 33 engine save some money for a bottom end cause it'll hurt a rod eventually
  • Like 1
  • Thanks 1
If it is purely for street use and not used in a competitive motorsports environment, then 300kW is plenty for a car with basic suspension modifications (i.e. a set of coilovers) and the factory LSD.
270~300kW is very achievable with a small budget and will be "fast" enough and "fun" enough.
Once you start go to beyond that, expenditure increases exponentially where as before that it is linear some what lol.
Hypergear ATRG3SAT would easily do that on 98RON and give you a bit of headroom in future if you ever decide to spray some WMI or go E85.
Another question before you start throwing out turbo makes/models etc. is when you want the turbo to come? yes any big turbo can "make" the numbers you want but when is another question?
No point slapping a biggish turbo on your car to make only 300kW and have it come on late - very american mentality. "oh be dayem, it makes 500hp on a mustang dyno, and I dont' mind the lag because I'm american"
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
