What is the power range you want, and your setup etc?  It's hard for anyone to tell you which is better suited when you've mentioned two turbos which flow different to each other.  I'm personally not a huge fan of either in the current market, much better options for what both can do out there now.
The power range id like, would be around 350kw and at the moment the upgrades are, 750cc injectors, link G4 ecu, front facing plenum, 6 boost manifold and so forth, if there is a better turbo that is more suited for the type of set up I’m after, which would be more street but occasionally track.
Edited by Fr3akyR33
Ah that makes life simpler.  On 98 octane?   I can say straight out, a GT4088R is overkill for that power... though these days a GT4088R is pretty much pointless in every way unless you are pretty much given it.
Edited by Lithium
  • Like 2
For simplicity go internal.
External means you'll need a new manifold, dump pipe, wastegate, plumbing so on and so forth.  To go drive in drive out with a new external gated turbo you're probably talking $6k including turbo.  To do it internal you're looking at half that including turbo. (That's JUST to buy the turbo and have it fitted - NOTHING ELSE)
Note, you're going to need a hell of a lot more than just a turbo to hit your power goal.
350kw is going to be a $10k-$15k spend.
Turbo
Cooler
Injectors
ECU
Exhaust
Coilpacks
Clutch
AFM
Filter
Fuel pump
Fitting parts
Tuning
I suggest you stop worrying about specifics, ie. which turbo, and spend the next 6 months reading and researching these forums as to what you're getting yourself into.  It's clear you have absolutely no idea so you need to research like a madman.
Start researching for a well regarded workshop near you who you will get to do the actual work and then work with them, as well as what you can learn here, and start buying all the pieces you'll need to complete the jigsaw (after lots of research).  If you rush into it and start hanging all sorts of random shit off your engine, you'll end up spending $25k and you'll get a shit outcome.  Research, patience and knowledge is your friend.
Seriously for what you want just shove a gtx3071, a good exhaust and intake, a good cooler, a fuel system to feed and an ecu to control it and a clutch to hold it
and if it's a 33 engine save some money for a bottom end cause it'll hurt a rod eventually
  • Like 1
  • Thanks 1
If it is purely for street use and not used in a competitive motorsports environment, then 300kW is plenty for a car with basic suspension modifications (i.e. a set of coilovers) and the factory LSD.
270~300kW is very achievable with a small budget and will be "fast" enough and "fun" enough.
Once you start go to beyond that, expenditure increases exponentially where as before that it is linear some what lol.
Hypergear ATRG3SAT would easily do that on 98RON and give you a bit of headroom in future if you ever decide to spray some WMI or go E85.
Another question before you start throwing out turbo makes/models etc. is when you want the turbo to come? yes any big turbo can "make" the numbers you want but when is another question?
No point slapping a biggish turbo on your car to make only 300kW and have it come on late - very american mentality. "oh be dayem, it makes 500hp on a mustang dyno, and I dont' mind the lag because I'm american"
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
