You're better off with a Hypergear turbo to be honest.
His latest high flow will get you close to 300kW on 98RON in the stock location, stock dump, etc. (Just need the right supporting mods).
On E85 or WMI you'll easily go 350kW+
Is there a reason you push hypergear so much over other brands? I notice it's not just in this thread but plenty of others as well
In context there are probably not many current alternatives which bolt on so easily and perform fairly well - though as soon as you go to custom piping etc I think you're better off looking at the likes of Garrett etc.
  • Like 2
Best reason I can think of.  They are a bit cheaper but they are also relatively laggy for the power they make compared to more popular/big name options - in my experience
Edited by Lithium
I’m open to opinions and reviews on turbos that you guys have had in the past.
Ive had a look at garret, precision, kinugawa, hypergear, done research on all and it’s between hypergear and garret probably! Still learning as we discuss anyways.
It's because it's a complete bolt on solution, yes a GTX3071 "might" be bolt on, but you still need a new intake new water/oil lines and by the time you're done that's nearly double the price of a Hypergear.
Most GTS-t owners:
  • are on a budget
  • usually do the work themselves because of point 1
  • want power fast
  • want not so much lag
  • want plug and play
If someone had a built motor, and wanted 400kW+ etc. said they wanted power/response for roll racing/track work then I wouldn't recommend a Hypergear. There are other threads where I've mentioned GTX3576s or EFR8374s, etc.
Just to be clear, I am not sponsored by Hypergear nor is there any financial benefit for me in recommending the brand.
I met a guy having trouble with an rb30 chewing through gt3582r turbos with .63 rear.
What ended up happening was rear of chra turned blue and cooked the bearings.
They only lasted a few thousand kms.
Put a Borg Warner airwerks on with bigger rear and the car fell apart around the turbo.
I'd imagine a .82 on 3576 would work much better.
  • Like 2
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
