Hi all
i have a stock rb25 neo for road use. I'm considering my turbo options, current spec is gtr 570cc injectors, hks 2530, power fc, intercooler and the usual bolt on stuff
ive had plenty of skylines and silvias but never had anything top mounted so I think it's time
i have not got massive power figures on my agenda, but response and solid boost while not pushing the neo to hard. I've narrowed it to the gen2 5558 precision or the gtx3076 gen2, any opinions ?
i will either use 6 boost, sinco or a CRG manifold, v band likely
and need advice on a wastegate too, is 40mm enough? It will run 98ron and
I have a r35 gtr afm which I hope will cope ?
thanks
I have a 7670 and personally reckon it's a big big for a stock 25. I have a 2.8 and wished it was a little more repsonsive, I don't think i'd be happy with it myself on a 2.5.
My vote is for a GTX3071, but if you demand specific power and only have access to 98, you may need to have some lag to get there.
  • Like 1
I'd be looking at your setup, there is an issue somewhere. Your 7670 is "coming on" at the same time as my 8374 and I don't have VCT. (All on at 3500 rpm rolling it on in second).
A 7670 would be epic on a RB25.
  • Like 1
R35 AFM might tap out unless you run it in a larger pipe say 3.5" or run it on the cold side before the TB.
I did a S15 running a R35 AFM, although in a 3" pipe without any air straighteners installed and it was hitting 4.8V each time it came on boost for a car only making ~240kW.
I prefer the HPX version of the R35 card as it supports more air flow in the same pipe.
@bri73y runs an EFR7670 on an R33 GTS25t (still RB25) on 98 and from all I can tell he is pretty happy with it's performance, he shared this dyno plot (EFR7670 vs HTA3076 on pump gas) showing the 7670 making near 370rwkw and 200kw by 4000rpm
  • Like 4
Mr Lith could you pass on the final results of that RB25 you knew of with the EFR 7064 , think it was T3 IWG on the standard exhaust manifold .
Sounded like it was really strong for something with number plates , and not exactly lacking round town .
I reckon this would be really nice on a street Neo powered Skyline .
We still haven't had a good dyno session with it thanks to boost control and ignition issues - I think we hit around 280kw @ hubs before ignition break down stopped our last session, however we've got it holding around 21psi on the road now and no misfire so hopefully when we next get on the dyno all will be well.
It builds boost VERY similarly to an HKS GT2535, but with the EFR "transient response" and more turbine flow - so more power per psi, it's pretty good for a >50lb/min turbo.
Edited by Lithium
  • 4 weeks later...
https://www.sau.com.au/forums/topic/472431-r32-gtr-efr-7670-build/
Check this thread above^^, and read in conjunction with Lithium's comments in this thread to your question.
IMO the short answer is "no".  You don't "need" split pulse to achieve your performance targets.  But if you have the budget, yes you should consider it - but stay IWG for the relative simplicity of install.
There's enough accumulated experience that suggests a properly executed EWG setup will be a performance improvement on an IWG.  Comment applies to single scroll and twin scroll.
I wouldn't discount the idea of a well designed manifold/gate setup, and a reasonably high spec single scroll turbo.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
