Hi guys,
I have up for grabs my OS Giken OS88 6 Speed sequential gearbox. This was originally purchased in October 2014 and received June 2015 after an 8 month wait from OS Giken.
This is the updated version with the extended sump on it.
I optioned this up with "option 2" gear ratio's. (This is an extra $1,000 option over the standard box price). This has the shortest 1st and the tallest 6th (6th same as the factory R32/R33 GTR 5th speed) so it's not spinning higher than it needs to be on the freeway. The ratios are;  Option 2: 2.890, 1.981, 1.468, 1.174, 1.000, 0.757.
I have also upgraded the gear position sensor to a Novotechnik Item as shown in the photo's below. This does away with the OSG 'switch style' sensor.
The box has done no more than 350 km's on the street and a full flex tune on the dyno, so it's as good as brand new. Motul 75W-140 fully synthetic oil was used. That was the product recommended by Award Diff and Gearbox. It will not be driven again apart from the 15-20 odd Km's to where it will be removed.
Whats included?
- OS-88 6 speed sequential gearbox - Option 2 ratio's.
- OS-88 transmission crossmember for BNR32/BCNR33
- Novotechnik gear position sensor
- OS-88 Adjustable release fork kit
- OS-88 direct shifter kit (bent style)
- Release bearing
- Gear indicator
The gearbox is currently in the car and will be removed within the next couple weeks. I will be happy to take someone for a demonstration drive, HOWEVER, not without a $2,000 deposit. If you're interested in the gearbox you will (well should) know what they're about. The transfer case in those photo's is NOT included. I need that!
Apart from the clutch (I used the OS Giken R3C) this is a whole and true bolt in package.
Location is Georges Hall, Sydney. I will post at buyers expense.
Contact me VIA PM.
Price is $16,000
  • Like 2
14 minutes ago, I will said:
10k cash
I will speak on Pauls behalf...... wake up mate you're Dreaming!
Edited by Mick_o
  • Like 1
Why do people think cash in a private sale has some mysterious pulling power lol, it's not taxed, so what else you gonna pay with...Bitcoin?
Paul chuck the ad on the Pommy site. With them buying in pounds to the aussies peso you might get more sniffs.
Freight to Europe easy to sort but import tax to UK would rip anew orifice.
Worth a go as going to be one of those slow sells as unique piece of equipment and will only suit a refined buyer or drug dealer.
  • Like 1
46 minutes ago, Mick_o said:
Or how "cash" makes it worth 40% less than the asking price? ?
You don't understand high finance Micko, Brett's and many other blokes $1 "cash" is worth $1.45.455 to them , easy :pirate: I think lol
Nice try Brett, no wonder you could build that beaut car :17_heart_eyes:
  • Like 1
  • Haha 2
1 hour ago, Mick_o said:
Yes! Thats why he gives it all to the GTR ?
haha, thats not bad for a bloke with a massive hangover , I guess :nyaanyaa:
Bet Heckle is feeling no pain
Hi piggaz.. if you dont mind can i know the novotechnik sensor work well? do you connect them back to OS gear indicator as well or run other type gear indicator? I think mine f***, plan to replace them when remove next time. what model are they?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
