I was reading about a guy in the states who did a 'LCI conversion' to his E90 by sticking red tinting on his tail lights. While this is in no means an 'LCI conversion' I thought it looked so much nicer than the clear reverse lights so I bought some pre-cut tint from the states and put it on today. Its not perfect with some tiny air bubbles but I'm hoping that by leaving them in the sun they might go away, I think it looks so much better as the tail lights are, for me, the weakest design link on this car.
  • Like 2
imageproxy.php?img=&key=4b1e78680f916b86
Um but do they glow red when you are going backwards? Would be illegal and confusing.
  • 4 months later...
I just realised how long its been since I updated this.
So, I'll add what I've done since March.
Oh, also, my VVT motor is leaking oil into the spark plug holes #3 & #4. Its not much of a leak but its causing the odd miss which is irritating me. Been quoted $800 but it looks pretty straight forward and might give it a go myself.
Also, during my must-keep-warranty 6 month oil change my intake pipe was noticed to be not entirely attached allowing unmetered air into the engine. This was fixed which made the car a little more responsive.
I changed my angel eye bulbs to LED's. I purposefully didn't get stupidly overpowered ones as I didn't want the angel eyes to be like little suns, I just wanted them whiter than the halogens and slightly more noticable.
Here's drivers side done, but not passenger. Fairly different, passenger doesn't even appear on.
Both done in the daylight.
Here they are at night. Not bright enough to light anything up, which was the desired effect.
I need to get pics of my interior changes...
But, I totally had enough of my seats. They were horribly uncomfortable and like sitting on a bench.
I got some absolutely mint M-Sport seats. They are soft and the leather is gorgeous. Lots of left and right thigh support and an extended thigh base at the front. They also have air-filled bolsters though if you are larger than the average 3 year old you may need to leave them empty as they get seriously tight.
I also picked up a BMW Individual steering wheel! Its so fricken cool though a little banged up. I'm trying to bring it back to its former glory but its already so much nicer to drive with than the bus wheel that was in it before.
One thing I noticed on the car the first time I saw it was the terrible state of the window seal trims. The front windscreen is totally missing and the rear just looked horrible.
Here's how it looked and it was killing me every time I looked at the back of the car.
The other issue was that somebody had glued these pieces on which was a real mess.
Anyway, once they were all off I gave the glass and the car underneath a good clean and then a spray with silicon to assist in getting the new trims on.
End result is so nice. Its one of those changes you make that you keep noticing every time you look at the car. Seriously satisfying, its been eating at me since I bought it.
Some black glue still on the paint to this day, need to hit it with some bug and tar remover.
Passenger side isn't perfect but no amount of manipulation would fix it. I just left it, as its not glued in I might try to fix another time.20180721_150442.jpg
My drivers side tail light has always been cracked. I picked up a replacement and its another satisfying fix. Its so much cleaner than the other side though I'm now considering buying its pair to make both sides nice and clean.
Anybody know how to get this off? Its so irritating and no amount of scrubbing even makes a dent.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
