I mean, I think half the reason  they sound so good is  because they are not using traditional  merge collectors. The original gtsr unit has a flat style collector, the reproductions shown in this thread have angle-cut pipes, but the collection is still "flat".
Could  one not just use two 3-1 flat collectors and the exact same pipe lengths as the original item?
Then again,  I can't fabricate so I could be missing something obvious here.
Whilst i would absolutely love a genuine R31house item i would never support speedtek in any way shape or form, even if i was receiving a free manifold from them. f**k speedtek.
  • 3 weeks later...
The speedtek manifolds don't even come close to the quality of the R31house equal length, single piece, hand bend runners.....
They're no where near equal length either.
I've spend literally hundreds of hours searching and attempting to translate any info over the years on gts-r manifolds and especially the R31house manifolds and his journey to recreate "that sound" and from what I have found, there's been three iterations all up now.
The first was the long large diameter merge type:
The second iteration is the one I have called "max" :
And the latest version 3 is the "premium" which just launched a few months ago, here's a pic of one with an original gts-r:
I managed to translate a blog post from R31house from a few months ago stating that the particular sound that R31house refer to as "that sound" comes from the pressed plate steel merge collector on the original Hr31 gts-r manifold and they've only now with modern tech been able to 100% recreate the original and finally achieve the 20 year long goal.
Another interesting translation was that he said he felt his car lost response and power with the v3 "premium" compared to the v2 "max" because the runners end at the start of the plate steel merge with the openings facing directly at the inner front flat face of the merge collector and this creates turbulence BUT is the precise cause of "that sound".
I also have seen two versions of the actual RB20det-R GTS-R manifolds as well, the normal 1-800 homologation Hr31 gts-r manifold with press bent like runners and heaps of splatter from the welds Etc.:
Then there's the Hr31's that the racing teams like Reebok, Calsonic and Gibson etc. received and the manifolds they had was the same design with much, much higher quality materials, runner bending and welding...
The ReeBok car:
I even tracked one down 5-6 years ago on a sale thread and contacted the guy selling it and it turned out he was an actual mechanic for Gibson Motorsport and the manifold he had (sold) was unused because when they received the hr31 race cars, Gibson removed the manifolds immediately in place for the custom Aussie made Gibson manifolds, this is that actual for sale thread photograph:
And obviously this is the Gibson manifold:
*all photos taken from google
  • Like 3
I genuinely love these manifolds and live to share the information to those who also have a genuine interest (:
And I have actually left out a couple of others hahah...
The Hr31 Autech had shorter runners and a smaller merge collector into a t28 flange which was widely rumoured to spool a lot faster and produce better numbers than the gts-r manifold even though it's wasn't equal length:
R31house has also done a couple of the Autech recreations in the "max" v2 style, note the unequal runners:
  • 2 months later...
Just had this arrive fresh from the motherland, a piece from the owner of R31house’s personal inventory..... A brand new completely unused GTS-R turbo manifold still with the original Nissan part number label on it ?
Feast your eyes.....
  • Like 1
  • 1 month later...
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
