Originally posted by Nightcrawler
Maybe, (in order to make Brad and my results MUCH better), you should find out the dry weight of each car and post the power to weight ratio alongside ;) .... hmmmm I think my 1240kg weight is to my advantage :)
Personally, I would prefer to use the wet weight, I tend to have engine problems with no oil in the car. Since the dyno has measured rwkW. The combo of the power getting to the road with the weight on the road is a good thing.
  • Replies 104
Originally posted by Clint32
Martin would you mind giving your opinion on my setup I am currently planning/building for my 32.
HKS T04e, recod with new comp wheel .6A/R exhaust and comp housing
Turbosmart external gate
PWR 600 x 300 x 73 cooler
3.5''exhaust
044 pump with GTR injectors
New inlet manifold (due to my ability to make myself)
Run by Halltech probably
Hopeing for about 230-240 @ the wheels, will it work
You SHOULD make that power. You dont need to go that far though, which is my point. Use a bolt on HKS 2540, use the cooler, or a second hand GTR unit, modify the plenum to make it front feed, use the fuel pump with an adjustable reg set to 55psi base. Tune the stock management, make 240rwkw no problems at 1.3 bar. Save a heap of money. 'Brains' did it.
Hey,
Does anyone know what the VG30 turbos are like?
I am thinking of buying one to rebuild and put on my 32,
is it worth it or is there a better option?
Anybody that can help me out it would be much appreciated.
Martin, I understand what your saying but I have a full engineering workshop with everthing I need, so for me to that would be too easy. The turbo, wastegate and manifold mods cost me $1700 so about the same as a s/h HKS turbs and all my stuff is like new now. I have already modified the stock plenum already but I was not happy with the stock insides, dont think it would flow evenly. I will use the bottom runners and make a top half, easy. The intrcooler core is only $500 so it is better and cheaper than a GTR. The only reason I want to use the Haltech is it will do a good job and will give me somethink to play with and moniter things. I really just want to try and do something different and learn something other than bolting bits on ( I am doing and Engineering degree at uni).
I've posted a bigger spiel in the "Performance" section but here's a quick update, & a few well deserved thank you's.
Martin recently spent some time on the dyno tweaking my Microtech LT12 - The end result was a nice safe, yet reasonably decent, 257rwkw on 13psi.
Thanks to all involved, including but not limited to -
Martin for his friendly assistance, time (one very busy man!) & tuning knowledge.
Mark for the dyno time.
And a special thanks to Tim/Ivan & all the boys @ RPM/Horsepowerinabox for the considerable number of hrs in hands-on & tuning.
:D
Matt
Finaly some ones seen the light, MoTeC is the best u can get. Many of my friends drag cars run the M8 system, its is without doubt the best setup for most cars.The M8 can be triggered by either a hall effect switch, a logic drive or a magnetic sensor. There is no EPROM with these setups as it uses flash memory cards which r very good. Proper stuff that is. Optional features on the M8-Pro include dual high accuracy fully temperature compensated wideband lambda (mixture strength) sensors and 512K internal data logging memory. " very kewl stuff ". This microcontroller contains over 420,000 transistors. That the M4 reads its sensors 2400 times per second, and the entire control program is recalculated 200 times per second demonstrates its power. 200 samples a second , " I got to get me one of these " :]
Coupled with a NTK UEGO Sensor and a MoTeC Professional Lambda Meter (PLM) its a very good setup. Also if u wanna spend some more money get a MoTeC CDI/8 Capacitor Discharge Ignition for the ultimate setup. It can be driven by a single wire from a Motec ECU or can be used standalone with full RPM and Load mapping of the ignition advance.
You can get some serious datta logging with these MoTeC systems witch will help tuning the car so much easier. A laptop computer is a must for tuning, im sure some one has one u could use to do it with. Ask Munro nicely :]
Well theres some food for thought.
Im sure Martin can give u some more advice on what would work best for your needs but that setup i mentioned is prob the best u can buy for your car. Costly upgrade though well WORTH IT if u want serious perfomance.
:burnout:
Thanks mate, I have been reading up on them and I know the M800 can do just about anything you want. I probably dont need to go that extreme a M48 would do the job nicley i think, its not a race car just a street car that may d the occasional drag. It should hopefully run all the factory ignition. I was going to get a Haltech but a company we do work for uses them on trucks they convert to gas so I will be able to do some work to get it.
! main reason for this is ppl r cheap skates. To many ppl try to save a few $$$ and buy cheaper stuff i would call "crap". Thats the reason most ppl know nothing about them. MoTeC owns all others. Not that it bothers me cause i use carbies:] Next thing u know ppl will start bagging MSD ignitions. Whats this world coming 2. Maybe we should sell all our cars and buy Barinas.
Originally posted by GTR King
Martin this Martin that , man the sun must realy shine outa his ass hehe. No wonder he doesnt answer ide get sick of it too.
Strange thinking Brad! The Motec will do the job perfectly though. Dont worry, just get it.
Hrmm Ok then..
So would you say that the Microtech was the Cheaper crap then? :P
If it works who cares.
We arn't really building mega dollar drag cars here.
More i'd say Budget $$ performance cars that are reliable.
For example I have no need for another ECU.
So why bother an ECU remap will do fine.
Chill... :burnout:
GTR King - How can you call people who buy Microtech etc. cheap skates?
Thats bullshit
Does that make me a cheap skate when I get my computer re-mapped to suit my mods instead of buying a Motec, and what about people with Power FC's, are they cheap skates as well?
I don't think so - just smart, because with most of the mods everyone has a Re-map/Microtech/Power FC is perfect
We don't drive JGTC cars - just quick road cars
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
