Hey guys,
Have recently had problems with excessive blow by at the track. I have an at performance catch can with 2.3l capacity and fill it up after 5 or so laps. Have been told this is normal for Rb's but seems pretty excessive. I have seen peoples setups to drain from the head back to the sump but a healthy motor shouldn't need that? Im only running 250hp with a standard high flowed turbo. Thinking i need a rebuild but want to here peoples thoughts.
Do freshly rebuilt rb25det's still push oil out at the track?
TIA
Agree, not normal. I hardly get any after a whole day of thrashing (40+ laps)
The only time ive had a fair bit was when i had overfilled the sump too much, i now only run 300 ml extra oil above the h mark and only get a few drops worth by the end of a track day. No oil mods at all.
built motor or unopened? what sort of breather setup are you running?
Unopened motor, no breather. Catch can is baffled and attached from passenger side rocker cover and then plumbed back in to intake. Car makes over 300rwkw on e85 and high flow turbo and has done over 20 track days like this without issue.
Edit, factory pcv setup is also still present and functional.
Nice mate, sounds like a strong motor. Do you think the pcv helps with blow by? Any pics of your catch can setup?
No pics of catch can atm. Its just a home made job using steel wool and some wire mesh plate as baffles. Ill try to get a pic for you tomorrow.
The pcv does help when used in a factory or plumbed back system. I believe you are meant to remove the pcv when venting to atmosphere.
Have you done some basic checks on your engine, like a compression test just to get some idea of condition. That should show if there is something drastically wrong.
Do a compression test to see if you have the dreaded broken ring lands (or just some broken rings. If compressions are fine have a read of this thread (start about 2/3 way through):
Thanks man, yeah some good ideas there, I'm definately up for a rebuild, will be doing these before re assembling.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
