R33 gtst Slight missfire on idle... Spark plug gap suspect
Hey guys, ive done some reading up on this but want to get other peoples opinions on changing spark plug gap and whether it will affect my tune. So far i've checked coil packs and replaced with brand new splitfires, new ignition module a few years ago, new fuel pump and injectors, New z32 afm, all vaccum hoses replaced as well as headgasket and intake and exhaust manifold gaskets with genuine nissan items. Tps and aac valve are both relatively new as well. Car is tuned on e85 running a power fc. Made 408rwhp on stock motor and pulls hard with no missfires or hesitation. The only time it does miss is on idle and seems to splutter a bit under 2500rpm. Its only a very slight miss like a cylinder dropping sound but is more noticeable when warmed up. Im running ngk bcpr7es plugs gapped at 0.8 but was wanting to see if 0.9 gap would iron out any idle miss im having and not massively affect my tune. Cheers guys
^^^ as per GTSBoy says, That gap is only needed when you're boosting.  At idle or just above, it won't matter.  Generally at idle you could have just about any gap in the 1.2 to 0.8mm range and it wouldn't matter.
See if it still happens with your A/C turned off.
Cheers for the input so far guys. So with the a/c switched on there is literally no miss! It idles at 1000rpm but the miss comes back when its switched off. Once the car is at operating temp it idles at around 850-880rpm. I also noticed when i unplug the o2 sensor the miss goes away completely but the afr's drop to around 13 on idle instead of sitting on around 14.7 which i imagine is normal as it was tuned with the o2 sensor. Does this mean theres an issue with my o2 sensor or possibly the wiring?
Missfire on idle? That's just called 'having any RB engine'
Thats what the tuner said too lol he couldnt pick up any faults with anything but surely it cant be normal. It sounds shit on idle! Slight miss every few seconds rather than idling super smooth like it did before. Oh well i might just have to live with it then
O2 sensors get old and slow.  The heaters also stop working and they don't then work when cold (ie at idle).
O2 sensor was also replaced not too long ago with a genuine nissan sensor as previous one was getting on.
Just an update guys...had a mate of mine double check the gap on my plugs and turns out it was only around 0.5mm! Pretty pissed off as a reputable tuner gapped them for me too! Anyway they're now gapped to 0.8mm and no more miss what so ever and the car obviously feels smoother too. So...yes, spark plug gap can affect a cars idle lol
I wouldn't call someone that doesn't know the difference between 0.5mm and 0.8mm spark plug gap a reputable tuner. Did they have a reason for the small gap?
He didn't mention anything to me about the small gap. He told me he was originally going to gap them down to 0.8mm. The plugs really shouldnt of needed much adjusting anyway as the bcpr7es come pre gapped at 0.8mm. He was also trying to say the miss was a 'skyline' thing lol the car feels great to drive but now im a bit skeptical on the tune if he cant even gap plugs.
Yeah I'd be too. It's strange when people say "reputable tuner", where did they get the reputation from? Instagram/Facebook or here on SAU? Or did they start off good and then got lazy/sloppy/dodgy (reminds me of a certain welder)?
I totally agree with you! The tuner did look after me though during the whole process and didnt charge me for a couple of dyno runs as we were diagnosing issues. And from what i could tell, he was a very honest, upfront guy. A mate of mine recommended him and a few of the boys on sau have had good results too. Im not too familiar with the pfc hand controller but is there a way i can view the fuel map/settings and post a pic on here so someone might be able to tell me if it looks like a decent tune?
On 28/04/2018 at 7:52 PM, Ben C34 said:
Keep in mind it probably wast the turner who gapped the plugs, could have been a different guy so not really fair to blame one guy
Yes sorry, I meant to finish off my previous post with this but I got distracted and hit the post button too early.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
