Hi guys,
In need of some expert/experienced opinions, It's a 1990 r32 gts4 that I purchased, I have liked skylines for a long time now and decided it was time to buy one, I was in over my head when I purchased this. What should I do? I've been offered 1k for it, i think i might try to get him up a bit but it won't get anything past 2k on a good day. Passion has gone and no where permanent to store it until I can give a shit again. It's killed my enthusiasm for cool/fast cars.
Problems:
  • no driveline
  • no interior
  • no diff
  • full respray would be needed
  • rust piece near rear window
  • Has a piece of metal overlapping a part of the frame which looks dodgy
  • paid too much for it, needs almost everything replaced
If I do get another skyline I'll be hunting for a perfect condition one from a SAU member. Pics attached.
xIMG_20180424_122846.thumb.jpg.15fe1b29efdaffe564b7732cefb6bb56.jpg.pagespeed.ic.hcpkYwkOWe.jpg
https://www.sau.com.au/forums/topic/473884-should-i-save-it-or-move-on/
You've answered your own question. The love has gone - just cut your losses and don't buy another car until you can afford one that doesn't require a fortune to fix ...in fact do you really want a project or do you just want a car you can drive?
  • Like 1
You sound like you've made up your mind. I'd push it and see how much this guy will give you for it but if you're burnt out now I'd just move it on.
If it was a GTR Shell then I'd possibly consider storing and keeping it till you're motivated due to the value simply getting out of control but not a GTS4 - Time to make it someone else's problem tbh.
+1
57 minutes ago, mlracing said:
Junk it, what happened to the rear guards lol
Someone widened them, idk why. It looks worse in person, ruins the lines of the car.
It seems like way too much work even as is, i've been offered 1250 for it and i took it because it needs a lot of work and the bloke who's bought it owns GTRs so he should be able to get it fixed and on the road/track again. He will take me for a drive in it when hes got it up and running so thats a plus for me if he remembers. But after you saying the 34 is nicer/newer i'll probably aim for a clean 34 tbh.
I was looking for an easy project but I was in over my head after really thinking about it, i'll be aiming for a driving car that's stock or close to stock next time, I really wanted a car thats clean, stock and runs well that I can throw mods at instead of repairs.
  • 2 months later...
Agreed. If the passion still there for this kind of car, then make it as a project. But you have some hesitation as due to the condition needed to work in the car, then i must say... move on as the passion is not the same. :)
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
