Selling my Nissan Skyline R33 GTST 1994. I regretfully am looking at selling the car as I just do not get the time to drive it as much as it should be driven, as well as been given a work vehicle.
Details are as follows:
Engine/ECU/Control
-Built RB25 (have receipts for work)
 *Forged CP pistons
 *ACL race bearings - conrods
 *ACL race bearings - mains
 *Nismo Ring Set
 *Trust oil pump
 *Tomei Metal Head Gasket
 *Nismo Engine Gasket set
 *6L Race Sump
 *RB26 Rods
-Haltech platinum pro
-Haltech 4 bar map sensor
-Haltech air temp sensor
-AFR Wideband Kit with Gauge
-Flex Sensor
-150psi oil pressure sensor
-150psi fuel pressure sensor
Turbo/Intake
-GT3080 with 0.82 housing
-T3 manifold
-PTP Turbo Blankets - TURBO BLANKET LAVA
-40mm turbosmart wastegate
-Turbosmart kompact blow off valve
-Plazmaman plenum
-Plazmaman fuel rail
-Plazmaman piping
-Large frontmount
-Turbosmart E-Boost 2 controller
-Oil cooler
-PWR radiator
Fuel System:
-Turbosmart Fuel Regulator
-1700x ID injectors
-Spitfire coil packs
-Custom catch can
-Radium surge tank in boot with 2x walbro 450 fuel pumps with 50amp relays and wiring
-All black teflon braided lines
Suspension/Drivetrain:
-NPC twin plate clutch
-Rb25 gearbox
-Hardrace camber and toe arms
-Hardrace traction rods
-Full HICAS eliminator kit (not lockout bar)
-BC racing coilovers
-Evo big brembo brake rotors caliper setup fronts
-345mm Rotors front
-R33 gtst standard rear calipers
-DBA slotted rotors
-Pumped guards
Wheels:
-Discontinued BuddyClub wheels powdercoated black 15x8 +32 5x114.3 x2 (drag setup with Mickey Thompson Et Street R tyres)
-Work Meister S1R 5x114.3
    Matte Black with polished black lip.
    Front: 18x9 + 22 = Nitto invo 225/40
    Rear:  18x10 + 30 = Achilles ATR sport 265/35
Other:
-Tuned by DVS Jez to make 330kW on 25psi on his hub dyno
-LETZGO plates included
-Carbon Fibre bonnet colour matched
-Rego till 29/10/18 (5+ months)
-Ran 11.8 @ 124
Negatives:
-Front left wheel has a slight bend (does not effect anything), right left wheel has gutter rash
-Gearbox crunches into 4th at high speed.
-Car requires an amp to rewire speakers to (removed as wanted nothing in boot).
Car has been maintained with the best parts and always serviced on time.
Has had the following done 1000 km ago:
-New oil
-New oil filter
-New NGK spark plugs
-Full system coolant flush
-Gearbox oil (hardline shockproof)
-Diff oil (hardline shockproof)
No test drives without deposit, no time wasters will be tolerated.
Can bring your own wheels for a cheaper sale price.
Price is $19,000 with both wheel setups.
https://www.sau.com.au/forums/topic/474014-r33-gtst-330kw/
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
