Yep, you need to set the pump up with a dial indicator and re-dowel as Mitchum has said. Obviously you don't go to these lengths for a basic rebuild.
Car was running on the dyno yesterday but ran out of turbo pretty early so had to stop it at 5k rpm as the EMAP was off the charts. I'll post a log over the weekend of rpm vs oil pressure
Looking forward to that.  Would be cool if you can post up learnings/logs in an appropriate thread for EMAP/IMAP too!
I mounted dial indicators on the north/south and east/west angles.. loosely mounted the oil pump and moved it upwards downwards side to side etc.. to see the total clearance in each direction.. then split the clearance and tightened pump down..
I didn't get the car back on Friday as expected, they are going to finish the dash config on Monday so I should have it back on Wednesday.
I'm going to have a chat with my local Motec boffin about some strategies to get it working more effectively. I can run a couple of comp tables to compare EMAP/IMAP/Turbine speed and EGT, I think I'll have to pull out a fair whack of timing at higher RPM as the EMAP gets out of control. The engine has fairly high dynamic comp to work with E85 and doesn't take much timing on 98.
I'm limited by the class of racing that I'm doing to using 'standard' housings. Obviously you can highflow but the 21u housing is choking the shit out of things and has zero ability to regulate boost so I've got some fairly radical plans for the turbine housing. Car made good power on 98. It's an RB20 (Roy would love it).
With the dial indicators, my engine builder setup two at 90 degrees to each other and measured the movement in the pump housing from the centreline then very slowly did up the bolts while keeping the pump housing centred using a nylon hammer and some love taps.
Edited by Komdotkom
  • Like 1
  • 1 month later...
As far as I know Spool makes kits only for old 81mm OEM and N1 pumps, while Supertec does for all pumps, except maybe HKS and Reimax. Also Supertec makes a high flow N1 splined kit with wider back plate, so pump flows 6 liters per minute more.
Black painted kits are Spool, genuine metal finish for Supertec. So Tomei, Jun/Nitto/Greddy pumps owners have only a Supertec option.
I have installed a Spool spline drive kit on my RB30/26 build.  I wasn't aware of the alignment problems associated with this setup and installed it without aligning it.  After about 1000 miles, my oil pump lost pressure about 1 mile from my house.  I got no pressure under 3k rpm but slight pressure above it.  But in doing so, I'm afraid the damage has already been done because I have a slight knock when I rev the engine past 2500 rpm.  I plan on pulling the engine back out and inspecting to see what went wrong.  Unfortunately, I stumbled upon this post too late.
On 12/11/2018 at 2:38 AM, mitchum said:
sorry to hear about the trouble, When i purchased mine it had instructions of how to properly align it..
Let us know what you find!
Could you post the instructions here please?
6 minutes ago, ENR34rb said:
This is a Supertec installation manual (attached). Not sure if it works for Spool.
Supertec_Splined_Drive_Manual.V4.1.pdf
Cheers man! It's more so just for the alignment of the pump to the crank.
  • 2 months later...
  • 2 months later...
  • 2 months later...
2 hours ago, ENR34rb said:
Finally Nitto made a splined drive kit. After all these years. ?
And after saying it doesn't work. Sounds funny now.
Pretty sure they said it wouldn't work due to the harmonics of the RB etc etc.. I guess they will be redacting their comments.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
