so i need to remove the radiator from my 250t rs four which has been converted into a 6 speed manual out of a 350z.
it is still using the stock radiator so it has lines going into the radiator for cooling the transmission from when it was an auto.
So, are the transmission lines connected at the bottom to the two brass fittings? (photo attached for reference)
these have nothing attached to them so i am not sure what they are for, other than that.
i think i may be mistaking the transmission fluid lines for something else as the lines I want to remove  are on the passengers side of the radiator and coming off the side of it.
this photo shows the lines i need to remove.
 Any help would be appreciated.
cheers
https://www.sau.com.au/forums/topic/474157-m35-transmission-fluid-cooling/
You no longer have CVT (continuously variable transmission) so not sure what you are worried about buddy. I have put a 300zxTT auto in my skyline and have installed a large cooler and i'm not using the little standard trans heater in the standard radiator. Maybe you are overthinking this.
Edited by Rusty Nuts
The new radiator you have is an automatic radiator, it is common practice to supply this radiator as a replacement part for manual vehicles, It saves stocking Two types of radiator in their store.
If you want to keep air conditioning remove that single fan, then remove that condenser and I hope there is a fitting on your new radiator to bolt it back on, Then reassemble and reconnect the lines from the compressor and take to aircon specialist for regas.
  • Like 1
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
