So I took the car back in to get to the bottom of it all. And so it begins.....
Text message from builder:
”I’m afraid the engine is gonna have to come back out man. I checked and double checked everything, then I ran the video scope down the cylinders.... Based off of what I can see in the pictures, there’s at least 4 pistons that are pretty beat up around the edges, pitting, small chunks missing, etc. I’m pretty certain there are some cracked ring lands on the pistons based off of the amount and location of marks/scratches on the cylinder walls. It’s odd that the compression test doesn’t show it, but it’s not uncommon. More than likely once it’s running and under load the compression is dropping off. The only way to know for certain at this point is going to be to tear the engine down and assess the damage to see what’s happening and what is salvageable. I’m sorry, I know this isn’t what you were wanting to hear. I was really hoping to find something else, but that’s it.“
So I am right on schedule with this RB26 GTR build. Start with a simple plan and make 500WHP, that turns into a complete rebuild with FORGIES.....
  • Haha 1
  • Sad 1
So, as of now, I am going to keep it a 2.6 and upgrade to the forge internals. The plan is as follows:
(Feel Free to add suggestions and input if you have any past/present experience with the parts below)
- N1 Crank (I have an early model 32 and would rather a new crank than deal with an American Muscle Machine shop)
- CP Piston 86.5mm 9:0:1
- N1 Oil Pump w/ SPOOL SPLINE DRIVEN BILLET OIL PUMP GEARS
- Manley H-Beam Rods w/ 3/8" ARP 2000
- ACL Main Bearings
- Clevite Rod Bearings
- ARP Head/Main Studs
- SuperTech 70lbs Single Valve Spring w/ Titanium Retainers
- SuperTech Valve Guides
- SuperTech Valve Set
- SuperTech Valve Seals IN/EX
- Tomei Poncams 262 IN/EX 9.15mm lift
- ACL Main Bearings
Don't believe there's a specific N1 crank... You just want to make sure you get the long nose variant (late 32 GTR onward)
Edited by mr_rbman
Update: Txt From Builder
”Hey man, I’ve got the bottom end torn down and it doesn’t look good. It has definitely been run low on oil a lot at some point and it has been run hard. It was just about to spin the rear most main bearing and/or 3 or 4 rod bearings. It has also definitely seen some detonation on several cylinders. There’s no cracks in the pistons that I have found but there has been a lot of skirt contact(piston to cylinder wall) there are some pretty serious groves. I honestly don’t know if 1mm over bore will clean it up or not. It also has the cracks on the deck between the coolant jackets and head bolt holes. I’m gonna check the cylinders to see if they’re egg shaped or not. The crank shaft is scratched up some as well from the lack of lubrication. I may be able to smooth it out with some emory cloth. I wanna get the head torn down and then I’ll go through and take a closer look at everything. I just wanted you to be aware of what I’ve found so far.”
4 minutes ago, reaper said:
Time for a new block
Egg Zach Lee.... I spoke with him today and we both agreed on that. No point in wasting time/$$$, so I am adding a block to my list.
Going to do some research for a couple days and see whats out there and all of my options.
So it looks like I will be dealing with a shop up north in Canada. I have reached out to a couple of them and have got the ball rolling on what I want. Will be receiving quotes hopefully all before Tuesday so we can get the engine to me by Thanksgiving (So about a month from now). Had three people send me their options they had for sale that stood out also.
Option #1
Original N1 Block (Not Heritage edition) w/ rb26 fully assembled, N1 block, lots of new parts, assembled at boost factory. But only things that aren’t stock are the arp studs, bearings, and cometic head gasket. Waiting to see if he's willing to do the block and crank separate.
Option #2
05u 86.5mm torque plate machined
Cp pistons ceramic and moly coated
Eagle rods
R34 crank
Reimax big oil pump gear
Ported head
Tomei Poncams
Supertech valve springs wi ti retainers
Tomei heagasket
Arp headstuds
Hks timing belt and gears
Acl race bearings
Tomei oil restrictor
External cylinder head oil drain
Custom in block cam trigger
76261462_10157366671961346_8050684268118016_n.jpg.f3e38b1966e907339f6a829ccc03e15d.jpg74428855_10157366671721346_2000822025353953280_n.jpg.387254ce863a6f655ecbc664bc17f863.jpg74317726_10157366671481346_2159797276287959040_n.jpg.3d4650f3007720c42451cdec5188fe12.jpg73460461_10157366671691346_1769490212003512320_n.jpg.0032d878ca2fd717cb9ee247b9031d34.jpg73155713_10157366671891346_3453432823023665152_n.jpg.419d4ac1b150a2b225b16d0e271a7d0c.jpg73088345_10157366671836346_5224247091840155648_n.jpg.c305e02bf06e650dfdff11fe3af2f656.jpg
Option #3
 built short block, crank with nitto extended collar, wiseco 86.5 pistons, Manley H-Beam rods
On 10/31/2019 at 11:38 PM, r32-25t said:
Don’t waste your time with poncams, get something with a decent amount of lift
You have any suggestions?? I wanted to keep the duration in the 260-264 range for my HKS 2530 set up on E85.
Also an update on the motor pull apart. Head off and ready to be cleaned up.
So I have got the ball rolling on the next step for this build.... I slept on it for a few days and decided that the best option for this would be to start it all from scratch.
After sourcing different options and not wanting to "trust" someone's word on the mileage, who built it, what parts were used, etc... I decided to go through a reputable shop in Canada. Saint John Engine Rebuilders. They have done tons of motors and supplies a decent amount of RB builds to the USA.
Bottom End As Follows:
Rb26 Block w/ bushed decks (for the common head bolt hole crack)
New Crank
CP Pistons 86.5 9.0:1
Manley H-Beams
N1 Oil Pump w/ Spline Drive
ACL Main Bearings
ARP2000 Main Studs.
As far as the head goes. I am still looking at higher lift cams for more torque while keeping the duration in a nice range for the 2530s. (open to input).
But the list of what I plan to do now:
Metal Headgasket 1.1-1.3mm
Tomei metal Gasket set
Supertech/Brian Crower Single spring & TI retainers
Supertech Valve guides intake/exhaust
Supertech valve seal exhaust/intake
Intake/Exhaust valves +1mm
9 minutes ago, r32-25t said:
My suggestions would depend if you want cams that work or ones that have a Japanese brand on them?
I want results. Who's gonna see "Tomei" or "Kelford"? Brands aren't priority on camshafts for me... Exhaust system different story lol
I’d go custom on the exhaust as well, cause the japs love to throw a restrictor or 2 in their exhausts.
unigroup does a camshaft set that are 260° with almost 11mm of lift
  • Like 1
So I’ve contacted Unigroup Engineers about their cams and I liked what I was told. So I’ll be going with the 260 IN/EX with 10.9mm lift. The CP Pistons states: “CP pistons are compatible with oversized valves and higher lift cams”
Due to this change I’m going to switch to a dual spring set up from SuperTech (SPRK-M1007D/RB) - 92lbs @ 40.70mm In / 82lbs @40.70mm Ex —232lbs @ 11.00mm In / 222lbs @ 11.00mm Ex Max Lift: 15.3.
About to start ordering the parts to get this in my garage by Christmas!
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
