Hey gurus. I have a bit of an issue..
s1 R33 Gts25t. Stock RB25DET .
Apparently has :
a hypergear turbo, EBay 50mms external gate with a screamer , boost controller, fuel pressure regulator, 3" exhaust and a big fmic and a forward facing plenum.
Now the issue is it's running really rich and fuel economy is completely stuffed. The bov has been removed and the pipes been routed to the back of the intake manifold. I have changed my Ecu and maf, and it's still the same.
I can unplug my tps and the car drives and.Runs normal, but if I unplug the maf the car stalls. Also if i squeeze the bov hose closed the car stalls... and honestly I'm lost as to where to look now.
Any help would be awesome thanks.
That whole setup is completely f**ked up.
The BOV return line routed to the back of the manifold is actually feeding the idle control valve.  Which is why it stalls if you crimp it.
You can't run a big turbo and altered fuel pressure etc etc against a stock R33 ECU.  It will tell you to go f**k yourself by making you fill up at every servo you pass.  This fits your description of your symptoms pretty well.  See above post.
thats what i was leaning towards haha , but ive not had time to look into the issues any further since i got the car. wheres the idle control meant to connect to? would be able to keep the hypergear turbo and sort out the bov/idle control piping?
The idle air control draws from the turbo inlet, via a combo of rubber and hardpipes that are attached to the original crossover inlet pipe arrangement.  The butchered plenum means that all that is gone, so the butcher found a way.  The BOV returns to the same place (turbo inlet, a separate port), so it's not incorrect for it to be hooked up the way that it is, just an ugly hack.
If you want a BOV back, you will need to attach it to the cold side intercooler pipe just before the TB and return it to the turbo inlet.  This is not strictly necessary - just depends on whether you like dose or like to have the inlet air bypass the turbo when on cruise (which is what it is actually for).
The main issue is the ECU.
54 minutes ago, Wrighty said:
thanks for help everyone, im thinking ill have to get a new ecu. but i still dont know why the car runs without the tps
Because the tps isn't a very important sensor for how 99. 9% of cars run
Original owner has wasted money on a FFP and a fuel regulator when what he NEEDED was bigger injectors and a tunable ecu...either a Link, adaptronic etc or for less money and a little investigation a Nistune set up.
  • 1 month later...
  • 7 months later...
fixed the IACV hose that was butchered by previous owner, also have worked out it just needs an ecu and a tune to sort the other issues out, has new coils and plugs now as well
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
