Hi guys, i'm new in the carworld and finally got myself my dream car. the R33
I bought a 1997 40anniversary R33 GT-S 3weeks ago. I gave it a service(change oil, oilfilter and sparkplugs) and the car runs great.
I don't drive much.
20minutes to work, and 20miuntes back home. There are times when the car is on for more than 30minutes(Incase i have to drive my gf somewhere before home) that my car sound turns into this gruggling noise but my meters seems like nothing is going on.
One thing that comes to mind that i am not using a coolant. Just using water atm in the radiator and i think that the water becomes so hot that it maybe causing the gruggling noise to happen.
I can get home, turn off the car and start it back up tomorrow and the sound is back to normal like nothing happend. just that if the car is on more than 30minutes i hear the gruggling noise(doesn't sound like a bubble noise, just a harley davidson idle ish overheat noise idk how to explain)
My car is currently at 394WHP if i'm on stage B(22psi) but its currently on stage A(16psi).
I tried hitting up 3 local mechanics but they told me it could be my thermostat or a blown headgasket but they seem too busy to give a hand. So i thought to ask on forums.
I thought maybe flushing the radiator untill the water end up coming out clean, and get an antifreeze coolant should do the trick but idk if the issue might continue.
Any help would be nice
EDIT: If this is the wrong section, can someone move it to the right section? It's hard browsing on my phone
Edited by Pastechi
https://www.sau.com.au/forums/topic/474723-i-need-help/
Welcome to :sau: !
Why no coolant? Whats your temp like when you hear this noise?
Do you notice any change to the performance?
Does it change in sound in sync with revs?
Can you leave it running after a drive to get it to 30 mins? Then stick your head under the bonnet?
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883312
13 hours ago, PranK said:
Welcome to :sau: !
Well i was planning on flushing the radiator and use a coolant end august but i thought it wouldnt be a problem, because i don't drive much
I do notice a change in performance, as soon as i heard the sound turn into this harley davidson shit, my acceleration feels slower.
Even if i don't rev the sound already changed. I need to put the car to work for more than 30minutes next time so i can record it. I think thats the best thing i can do to show the issue
Last time when it happend i turned the car off and immediately put my head under the car to see if i can hear any noise but nothing. Just quiet. After 5minutes of the car being off, i started it back up and the car sound went back to normal
p.s. this happend monday after work when i drove my gf home.
Ever since then i drove below 30minutes till this day and my car sound never changed.
Idk if i have a faulty coil, or maybe using water can cause it. Or maybe the thermostat is wonky.
Edited by Pastechi
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883351
14 hours ago, niZmO_Man said:
Umm, you'll have to be more specific about the location of the noise. Is it missing or running rough? Or some weird noise from the dash?
well i never found out where the noise is actually coming from because it only happend twice(and i only drove more than 30minutes twice so far) and i immediately turn of the car, i am a bit scared i may f*ck something up lol. What i did do after i turned off the car was stick my head under it to see if i can hear any sound from the radiator or motor, but nothing till where i know.
I'll see tomorrow(friday) when i leave work i can drive extra so i can get that harley davidson sound to appear again, then maybe i can record around the car and get the audio
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883353
10 hours ago, Pastechi said:
well...can i call it a harley davidson noise? because thats what my car sounds like after 30minutes
Harley noise, as in, it is misfiring?  When does it make the noise?  All the time it is running (once it starts)?  Only on boost?  Only at certain revs?
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883364
after 30minutes of driving the car, then the sound just changes on me. when i turn off the car and look around i hear nothing and i don't smell anything either :s
I did feel my acceleration be a little bit laggy tho
Edited by Pastechi
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883366
Get video.  It's not going to be possible to do this without seeing/hearing it, and the Carib is too far away!
Also, time a run to 100km/h before it goes bad and then another one after, so we can see what difference it might be making there.
Even with all that, I'm not making any promises.  This shit usually turns out to be something totally unexpected and strange, like a plastic sack wrapped around the tailshaft or a coke can jammed in the exhaust - that sort of weird shit.
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883367
Flush the cooling system thoroughly, put in fresh coolant and bleed the whole system.
The noise could just be the water boiling after the engine has had time to get up to temperature.
You should definitely be running coolant anyway to protect against corrosion and increase the boiling temp.
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883372
Simple question. Is the radiator full and the overflow bottle at the right level? As long as their is fluid in there you should get an idea of what temp it is running at.
If the temp seems normal (half or below), and there is no noticable leaks etc. then fair chance its not the cooling system. The stock gauge is not terribly accurate but i think you would see if there was a problem causing an overheat
It sounds like possibly a coil on the way out that only shows up when the coil gets really hot after a bit of driving, but as per above really need a video to show the noise
Last time I had a dead coil, could definetly tell that it was lacking power and sounded like a WRX
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883424
I drove the car for over 30minutes yersterday...try to get the sound to show up. Even burned some rubbers but nothing.
But yes....after 30minutes it sounds like a wrx and it lacks a bit of power....
I'll be checking the coils wednesday with a mechanic to see what we can find
I should also remove the cap where the coils are too..maybe its preventing heat from coming out
Edited by Pastechi
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883453
This is how my car sounds normally   (The noise in front of the car is 1 of the fans btw)
This is how it's supose to sound after 30minutes of driving(exactly like this wrx) and i feel a little loss of power
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883454
So i drove my gf home tonight and came back home. When i parked the car in the yard i heard the sound 90% changed but i couldnt rev it. People are asleep lol.
I recorded this yesterday and this is how it's supose to sound. Like always
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883464
1 hour ago, GTSBoy said:
They're both the same.  WRX one is just idling 300rpm lower than the "good" one.  Both sound normal but possibly with a slight miss.
ye...they are not the same trust me. but then again it did not fully change. I'm sure if i drove a little more it would of fully kicked in and it will sound so disgusting and the throttle lags and feels week.
Sadly it was late night so i didnt want to rev the car and see if the sound also kicked in. I'd wake up the neighbors if i do lol
EDIT: Now that i remember. by this time if i turn on the ac it would idle to 400 then 900 and keep going up and down, or prob kill the engine. The AC thing only happens once the car enter this wrx sounding shit
Edited by Pastechi
https://www.sau.com.au/forums/topic/474723-i-need-help/#findComment-7883472
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
