Ok, so, I've been having problems with starting my 98 R33 Gts-t recently. It can vary from turning over and never firing to starting but running very poorly and stalling to working fine seemingly at random. On more than one occasion, by playing with the fuel pump wiring, fuse or plug the car will start and run perfectly, i do not know if this is the actual problem because it seems so intermittent however, i do know that the car will run roughly/stall without the fuel pump plugged in (I swear I didn't forget to connect it, i was "testing"). If anyone has had a problem similar to this and fixed it that would be great to hear but being vague and intermittent I don't hold much hope.
The real meat of this post is, if i were to replace the pump is there a nice drop in replacement that doesn't cost and arm and a leg while not being from the Chinese lucky dip bag on ebay? my other thought was to upgrade to a Walbro 255 (GSS340) or a Bosch 040 because eventually my plan is to buy something reliable and diesel (and high off the ground so ramps aren't necessary for everything :) ) and throw some money into this car so i figured i may as well plan for power as i'm most likely to get a new car within a year. But i have read mixed things about both the bosch and walbro from a general trawl through the forums, is there a clear winner? Also if i do end up going this option, do I have to upgrade the wiring to the pump and what is the best way to go about this, my thoughts are to use the current power wires to trigger a separate fused relay.
Anyway, thanks in advanced for any help
Joe
Edited by joseph0205
Very difficult to diagnose over the internet, but a new fuel pump can only be a benefit. Clear winner is Walbro 255 which can be had for around ~$130 just make sure you buy from a reputable source online (EFI Hardware etc)
Also remove and clean AFM and check the wiring to the AFM isn't burn or missing a ground.
  • Like 1
I have found that the pump runs perfectly when just wired straight to the battery and the car will start and run beautifully so its down to either the wiring or the fuel control module which is conveniently hidden under the rear seat, wish me luck?
The good news is you can put the FPCM straight in the bin. Use the ecu fuel pump trigger (usually a pull to ground) to trigger a relay (any 30A relay should be fine) and then run a new appropriately sized wire straight from the battery, through the relay and to the fuel pump. Won't have any more issues.
That IS good news ? what is the use of the FPCM does it control the pump with PWM or is it just one of the Japanese complexity for the hell of it type deals (IE the idle air system).
Do you happen to know the colour of the ECU trigger wire?
Also there is already a large relay attached to what look like the main wires of the fuel pump attached to the side of the boot fuse box but it looks very OEM so I may have the wrong thing (I just matched the wire colours and that's never reliable)
Anyway, thanks for the terrific news
Joe
I know in R32 it's the white wire with purple trace however i have never done it with an R33 so can't comment on it directly. However with a multimeter and some googling i think you should be able to figure it out pretty easily.
Also the FPCM is just a two stage device, under condition X the fuel pump receives 10V and under Y it gets 12V. Better to run it at full voltage all the time.
fuel pump wire is black with a purple trace at the ECU...from memory.
And just before you go tearing wires out and throwing them over your shoulder, try running the pump with a dedicated earth wire first.
Plenty of time to go wire mad afterwards.
I have tried hooking a solid connection straight to the grey wire connection of the FPCU to ground and nothing has changed, so it is either the wire itself or something else i don't know.
I have drawn a little mud map of what i believe is the wiring diagram but i can't really make sense of it myself. So the black-pink/purple wire into the relay in the boot is the trigger from the ecu which must mean the blue-white is either a ground or 12v supply from somewhere (depending if the ECU pulls the black-pink/purple to ground or if it supplies it 12v) however, it didn't show any voltage or continuity with ground. (from memory i believe the black-pink/purple showed like 4M ohm to ground while the car is switched off so i assume that the ECU drops it to ground).
Now the light blue wire branches of to 3 places, the input of the FPCU, the front of the car somewhere and the main line into the  positive side of the fuel pump. The grey wire is what i believe to be the switch for the fuel pump by allowing it to connect to ground when the FPCU is happy (maybe i should buy it flowers or something, it doesn't seem to like me much) and gets triggered by an orange wire that i believe i have read is triggered by the ECU only when it senses the engine is turning (using either the force or the CAS, neither would surprise me at this point). this grey wire also runs to a random connector which is apparently a ballast hidden in the boot somewhere. Black is just the ground for the FPCU.
So my questions are:
1. Which of the black-pink or blue-white should be showing voltage and/or ground?
2. if i were to do away with the FPCU should i just have the relay trigger from the orange trigger line or go back further?
3. WTH does a ballast do?
4. How big was the average Japanese factory worker in 1998?
EDIT: I'm also planning on possibly future-proofing this whole system if i ever go for bigger power, will the light blue and grey wires handle, say a walbro 460 (probably never need it i just don't want to strip the car and wiring down like this again, just swap to a bigger fuse and go for it) or should i replace them with something beefier, i figure to handle up to 30amps. Will the ballast (whatever the hell that does) handle it?
42101595_1368794766590644_6112842449191698432_n.jpg?_nc_cat=0&oh=aa9f9c05836da12a692669ea50883d9f&oe=5C326639
Thanks for your help so far,
Joe
added more questions :P
I can't remember where I got those from, but used them to rewire the fuel pump in my R33 GTST track car. I think pin 2 is 12V through the ignition switch - so live when the key is on or start - and the ECU switches pin 1 to earth to run the pump. A couple of minutes with a test light would confirm this.
Joe
If you want to future proof it you will need to run a bigger supply wire and fuse...easy if your battery is in the boot otherwise you need to run a wire the length of the car. The stock trigger wires should be fine unless they have been damaged.
Yeah, it's all in the boot that's why I was thinking over doing it while I have it all apart. And the trigger wires LOOK fine but I was asking which trigger wire I should be using, the black-pink from the ECU that powers the whole FPCU system or if I should leave it be and just replace the FPCU with a relay and use the orange trigger wire?
So by looping the blue-white wire on the relay found in the boot to 12v everything starts and runs beautifully and by what i can find about a standard R33 GTST that's just how it is done (the first picture). However, unless this blue-white wire talks the long way and runs from the power source in the boot, through the cabin and back again to get 2 inches away from where it started it must be doing something else.
I also found a RB26DETT wiring diagram that does have the blue-white wire running to the front and into the O2 sensors on both the turbos. SO is there something different with the series 2 R33 or do i have a RB26DETT Loom in my car with a 25DET engine. I need to use the car so I am just going to wire it for now but any insight would be great.
Cheers,
Joe
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
