Hey everyone, I just thought I should ask everyone’s opinions on my problem. I plan on buying a Datsun c211 as a project. It will be my first project car and I don’t know what engines will fit without any major changes. Such as if any rb engines would fit?
thanks in advance to anyone that can help and I look forward to reading your advice.
https://www.sau.com.au/forums/topic/475180-datsun-engine/
21 hours ago, GTSBoy said:
All of that can be fixed too.  There's no point in building one of these as a resto-original project.  No-one cares about an old slow Skyline.  An old fast Skyline is cool.
Depends what OP is trying to do I guess.. around the world I'd say more people would be into the old slow (but sounds cool af with triple carbs) Skyline than an RB swapped basically S13 underneath..
  • Like 1
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888128
I like triples, but superchargers sound better.  I like superchargers, but turbos are massively better at making power.
In a world where NA engines are 6+ liters......~2.5L NA 6s are just missing something vital.  Power.  And torque.  This is fixed with boost.
The only old Skyline I would leave unmolested is a genuine GTR.  All others are fit only for scrap or speed projects.  Let's face it - the interior of any 1970s Jap car is no nice place to be, even if you drop cubic $$ on retrimming.  They are just nasty, poorly laid out ergonomic nightmares with twinky instruments and noodle thin control stalks.  You need something to take your mind off of all that when driving them.  Hell.....my R32 is a nasty place to be inside of, and it's not as if it's worn out and stuffed.  It is near factory perfect.  It's a hell of a step up from an R31, which in turn was a step up from the 70s.
Don't get me wrong - I'd have a 70's Skyline as a project (if I had the time/space/energy) in a heartbeat.  I don't hate them.  But I am very realistic about what they're good for.
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888135
It's definitely different strokes for different folks. Power is not what it is all about when owning these classics.
Decide what you want to get out of the car before buying engines. Remember going RB will be sump, fuel, diff ,gerbox mods. Plus you'll have to open up the tunnel to fit a larger gearbox. Then you will have engineering headaches if done legally.
You could put some triples on the engine, better camshaft, exhaust and have a nice car. If you want to go a little further you can do some piston swaps to bring up compression and/or port the head. Again, just depends on what you want to do.
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888819
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
