8 hours ago, kye32gtst said:
Hey guys, I'm looking for a deep sounding exhaust for my Gtst 32, just want to know what will drone a little bit, give the rb20 a deep note to it, and not have a raspy obnoxious exhaust. Thanks
Hey mate, you ought to be upgrading your exhaust system to increase performance not only to get better sound as you ought to nvest your cash on a good exhaust not any Autobarn/eBay one that might sound good.
Anyway, if you are willing to spend some cash for both performance and a better exhaust note then I recommend you look at brands such as Apexi, HKS, Fujitsubo and Tomei.
I have a 3” Apexi turbo-back exhaust and it sounds really nice but not too loud.
You need a budget, decide between an over the counter brand or custom and what dump pipes set up / catback or full system etc?
The JASMA mufflers will obviously have restrictors, but OP is after sound upgrade, so 2nd hand JASMA cat-backs shouldn't be out of the picture. Don't get X-Force though. Get two fat mufflers and get an exhaust shop to install it as GTSBoy said.
This is going to be phully sik!
I've been looking at a HKS Silent hi power, and a Greddy Power Extreme, but I can't find a decent sound clip of the Greddy. Standard dump pipe, Blitz Front pipe, and not sure on the test pipe. I've been looking on Nengun
Thanks for the replies guys, I appreciate it as I'm new to the scene
Hi mate,
Here's the HKS Silien Hi-Power one you mentioned:
If you want a more tougher droney sounding one...I highly suggest the Tomei Extreme TI exhaust:
1 hour ago, Robocop2310 said:
Hi mate,
I'm out in the Central NSW and the roads aren't the best and was advised by a mechanic, family friend, not to go with the Titanium because of the roads. Wondering if the Tomei Titanium would hold up, as apposed to a Stainless Steel HKS and Greddy options, also want to keep it stealthy to avoid unwanted attention, Cop lives at the end of my street :/
Unless you live in Antarctica, a titanium exhaust is not going to wear. Sound wise if you’re worried abito sound then why upgrade to a louder drone sounding exhaust in the first place?
Just don't want it to be obnoxiously loud, but still not stock
Custom exhaust from good local exhaust shop, reasonable size mid muffler and varex remote control muffler at back.
Leave home quietly without waking up the neighborhood or old mate copper and then release the hounds when all clear. My 2c.
I prefer mild steel over stainless, less raspy and deeper sound imo. Titanium = great=$
Titanium will make it raspy n obnoxiously loud.
Jap brand exhausts are shit. They hang low. Test pipes are illegal
As above go to a local exhaust shop and tell them what u want. They can make it fit snug up against the body and they won’t have any step downs in them
I've been told that cars before 1990 are not required to have a catalytic converter, so a test pipe would be perfectly legal. According to this mechanic
I've heard a few people say this too but never followed it up...I know mine doesn't and never been caught up for it yet.
It doesn't exactly help when I've bought the car with no exhaust at all. Not even a manifold. I'll blue slip the thing with a Cat if I can, but after that... There will be a little less choking the old girl
You can always get a temporary exhaust then take your time looking around for what you really want.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
