Currently have annoying misfire problems. The engine is RB30neo, after taking car to reputable tuner he replaced cas with secondhand cas , a coilpack, std fuel reg, fuel filter and said the fuel injectors are dirty and fuel filter was blocked.  So he road tuned car and said its better now.
Original issue was it running like a wrx for first 10mins, after that it was a rocket.
So now after it being at the workshop, it still starts like a wrx and now it has a strong misfire at 4k, right at the point it used to start breaking traction.
So i started it up and pulled one coil out at a time, cyl 3 and 5 not firing.  These coilpacks are brand new, have replaced them twice now.
So my question is what can cause cyl 3 and 5 to randomly not fire? Or are these splitfire coils fake copies?
https://www.sau.com.au/forums/topic/475431-misfire-problems/
3 hours ago, iruvyouskyrine said:
1. get a new tuner
2. never seen fake splitfires
3.get your multimeter out and start continuity and voltage checking. Also inspect loom for damage.
Yep that workshop gone to shit for sure.. not happy..
This morning i tried again, and cyl 3 and 5 dead, so i put 2 old coilpacks in and she ran sweet except heavy breakdown under load later when was hot.
So whats the chances of 3 brand new coilpacks failing on a cold start?
Loom is brand new from kudos, plugs new also..
What about the cas or ecu, can they play these kind of games?
I dont really have a clue about multimeter testing.
CAS "might" be cooked and the ECU is unable to determine a home signal, i.e. 1x full revolution of the CAS to determine TDC.
This could affect your car starting, however without using any tools it might be hard to diagnose.
Maybe try record your PowerFC hand controller with a GoPro or phone and see if there's a RPM when the CAS is rotated OR the car is cranked.
The coilpack harness might be new but i bet the main engine loom is not. I would start looking where is passes the exhaust, where it passes through the firewall and around the ECU header plug.
Youtube how to continuity test with a multimeter, its an excellent skill to have and difficulty level is 2/10.
1 hour ago, mr_rbman said:
Sounds like a similar issue i've had...
You running a Z32?!
Yep a z32, today again cyl 5 so i switched it with cyl 6 coil and just like that all 6 firing...
Will start looking into the multimeter idea and the cas test..
4 hours ago, AngryRB said:
Is this plug helping? Last set was a BKR7E that had a split in the electrode
That's a hot plug man, no way would I use that in a higher boost application (or any boost for that matter)
  • Like 1
Is it just me or is that plug gap huuuuuge?!?!?!
  • 2 months later...
Small update, i changed the plugs back to BKR7E and she has all the power back with no misfire's...
The issue still remains, that is i start it and its on 5 cylinders until i drive up the road and load it up in second gear , then it seems to clear up and runs perfect.. except for it usual jerkiness on very light throttles which i assume is the camshafts or maybe tailshaft slop..
So what could it be that clears up with some load applied, could injectors be need8ng cleaned after 10k and using ethanol? Diesnt ethanol clean shit???
Tuners explains it as it must be dirty injectors but after he put shit plugs in not sure if hes right...
Coolant is not going down and fuel economy is good, power is good, its just cold start on 5cylinders till loaded up.
Edited by AngryRB
    • Haha that's wholesome as! Looks like we're raising a generation of female rev heads and classic shit box owners 🤣
    • Haha nice, my kids are the same two older boys say cars are boring while younger girls like them. My 1.5yo daughter watches D1GP on YouTube with me, holding a toy plate for steering wheel and making brmm brmm noises
    • Took the car out to see if it still starts, sure does. Daughter wanted to for a spin too, she loves it when it doses, also cries when we come home and try to take her out of the baby seat 🥲  I actually put the seat in for her brother, but he absolutely hates the shitbox. Anyhow, so after looking at real boats, and transoms, bait tanks etc. and scupper valves attached to them, I came up with ideas to improve the catch can. The primary goal was to stop the interior smelling like vented catch can shit when the windows are down OR when the HVAC is not recirculated. My catch can has a sump drain/feed at the bottom, 2x cam cover inlets, 1x outlet back to the intake pipe and 1x vent at the top. The initial theory was at idle, and off boost there would be just enough suction from the intake pipe (pre turbo) to pull back any smelly shit from the catch can before it could escape out of the vent (which does have 1x layer of foam and a fine mesh screen on top). It kind of works, however on hot days, the motor is breathing more than the suction provided from the intake pipe (pre turbo) and there's a bit of vapours escaping (not a bit amount, but enough to piss me off). I could have just sealed off the vent, however it would mean each time I take it to the track or decide to drive it with a bit of enthusiasm, I would need to remove the seal. To address this, using scupper valve idea, I used a 3mm sheet of rubber and cut essentially a valve that requires a bit of pressure to crack open and vent. Took the shit box for a drive today, came back and parked the car. No heavy stench, great success ☺️ I still would swap for a F80 LCI or W204 2012+ C63 AMG, if anyone is keen 😅
    • I'm with Kinkstaah on this one. Do it once, do it right. So much better for your mental health. The sneaky thing about the fuel pump wiring is that it will work perfectly fine for the longest time. Until that one moment when it decides to shit the bed. And it's not worth the paranoia from not trusting the car anymore. At least other mechanical issues announce themselves by developing some noise or other warning. If you have the funds, I'd suggest to go with a good kit like Frenchys and get the work done by a trustworthy shop. No regrets there. The only downside to the Frenchys kit on the Stagea/R32 GTR is that their fuel level sender is not on point. But looks like the R33 kit maintains the factory sender so should not be an issue. This is what the botched setup on my Stagea looked like before it stopped working. It had melted its way quite a distance down. Glad it didn't burn down the car.   Some links I came across when I looked for solutions: Radium sells a DIY wiring kit that looks promising. I didn't buy it though, I let my workshop decide on wiring. https://www.prospeedracing.com.au/products/radium-diy-fuel-pump-hard-wiring-kit-17-0031 https://www.radiumauto.com/DIY-Fuel-Pump-Wiring-Kit-P368.aspx   You can also get cheap replacements for the locking ring depending on how mangled it looks: https://www.kudosmotorsports.com/Nissan-17343-79900-Fuel-Tank-Outlet-Locking-Ring-for-Nissan-S14-S15-BNR32-R33-R34-AWC34 There are tools for unscrewing it as well so you don't have to abuse it with a screwdriver and mallet. The Frenchys one is expensive but I'm sure there are cheaper ones.
