https://www.caradvice.com.au/704965/toyota-camry-avalon-trd/
I think they look ok. Not brilliant but ok. I was expecting to read an article about body kits and rims being the only upgrades but it seems they might actually be ok. Better suspension, better brakes and 19s. No extra power though but I think 224kw is pretty good.
But. They are still FWD. And they are still just bolt ons.
Should they be badged TRD? Maybe Toyota needs to bring back the Sportivo badges? [emoji1]
Should they be badged TRD? Maybe Toyota needs to bring back the Sportivo badges? emoji1.png
Heck, boy racers/ricers will buy TRD badges to put on their hand-me-down Camrys and Corollas anyways so what difference does it make? LOL
9 hours ago, GTSBoy said:
In a market where Toyota sell primarily taxis to taxi drivers/owners and 50+ year old Asians (so long as the car is silver)......does it really matter?
You forgot the Indians. They're getting richer now and can afford the higher trim levels.
  • Like 1
Indians are Asians too unless you’re referring to the American variety.
  • Like 2
Haha yeah, for those of you playing outside of Australia, people with Indian subcontinent heritage isn't grouped with Asians like in the UK but have their own grouping (curry/curries or just Indians haha).
Back on topic, Nismo, M, AMG are trim levels now so I don't see why TRD can't be one either. Shame the predator face design jumped from Lexus to Camrys.
But yeah, upgraded suspension, lighter wheels, bigger brakes. Those are decent upgrades. Camry comes with 300hp engine now, what a time to be alive.
I read good things about the original TRD Avalons, and I thought they looked pretty good too. These ones... i'm not a fan. This type of tuning seems to be the new entry level norm. I'm thinking C43 AMG etc.
Also I think we are entering another phase of overdone styling. The amount of plastic manufacturers are putting on their cars is starting to bug me. I think 18 year old me would have liked these, 30 year old me says no.
And I'm still angry they slapped an RZ badge on a Camry. ?
10 minutes ago, Dose Pipe Sutututu said:
Race Spec Camrys (Camries?), of course they need the TRD badge !
The scrape matches the vent! Good attention to detail.
Yeah, I hear this. Bodywork on lots of new cars just looks heavy and cumbersome.
23 minutes ago, niZmO_Man said:
I'm not going down that path haha.
Yeah the RZ badge, was an interesting one... maybe the new Supra will have an RZ trim too?
I heard the new Supra is going to be called a TRD Camry! No...but seriously, TRD badges on eBay are outselling the fake cheap GTR ones. Lol
  • Like 1
The new Supra has an m sport trim.
  • Like 1
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
