How long did he have it before you brought it. I don't know mat but I could swere Lachlan had it at one stage
Well, I was told Matt had it for 18 months and prior to that his uncle, no idea on his name, owned the car, but no idea how long his uncle owned it for..
ive been telling people that spend max 250thou on a Nismo GTR and youll be raping the 700000 cars out there. Not sure how true it is but the are almost as quick as a formula one at reaching 100km/hr
And you wouldn't be wrong. The GTR rolling off the factory is only at like 40% max power (my opinion/Guesstimate) - The GTR's were built to be modified - Nissan themselves said this on a Doco I was watching. These cars stock are very close to the Lambo Aventador which sells for $1,000,000 AUD.
Nsimo Williams who has been in works with Nismo to produce the R35 GTR N1 also admitted that there is more room for power. Also the 918 is a 800k car - it may be quick. But I don't think Nissan/Nismo tried to contend with the 918 Porsche. I think that is where the R36 will be heading - "be better then the 918, no acceptations" I think is going to be passed to the R36 creators.
Crazy cars - gives me cold chills thinking about the it.
Holy mother of rajab
That's what is "Said" not proven as per such. I wouldn't doubt it, however it actually hasn't been tested, so who knows ! However, 2.1 is gobsmack and the R36 will achieve 1.9sec. 1second car anyone?
Is the r36 even confirmed?
It is. It is confirmed to be released at the 2016 Tokyo Motor show - to which I am kinda wanting to plan to go and see.
R36 is a hybrid - The torque is electric given it more torque then petrol
Edited by RosieR34
  • 4 weeks later...
  • 3 months later...
Not the best pictures atm but don't have other ones on my phone, will probably come back and post other ones later
I have black manual r34 Gt-t with factory sunroof
Engine:
RB25det neo
3 1/2" exhaust
Turbo timer
BOV
The car made 158kw at the rear wheel on 6psi, am happy with that for now
Suspension:
BC/BR coilovers
Cosmetic:
Full z-tune side skirts
Gtr front bumper and bonnet
19x10 Varrstoen 3.3.2 black wheels
Modification plan has not been set into motion yet, but soon...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
