Hey! Just bout my first NA skyline (P plates) and noticed she's as slow as a snail and has rough as guts idle. Wondering if
A. A remap would help solve some of this issue aswell as get some power back
B. Would a Nismo ecu or gtst aftermarket ecu be compatible with the NA?
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/
A remap is not magic, it will not solve your idle issues. Any GTS-T ECU will not be compatible with an NA motor, the timing curves are completely different due to differing compression ratios.
An RB25DE makes about as much power as a modern economy car, the only way to change that appreciably is forced induction. Or if your engine is really in bad shape and needs a rebuild.
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7900947
6 minutes ago, 33bus said:
Bugger, all good thank you. Another quick question, would a FFP fit on an NA? I know there wouldn't be any power increase. Just looks
Although I think that it is possible, ask yourself is it worth it? A lot of effort (and money, unless you go a chinese FFP) for aesthetics.. If anything I think it will decrease the performance
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7900953
The idle being rough is odd.
Fix that and you may get a bit of power back.
Probs somthin easy.
Realy gotta rev the n/a for some power but dont kill it. Reasearch oil control! If ya gonna give it a hard time.
Not a big deal bein n/a as long as oil is picked up during extended gforce at high rpm.
Plenty of peeps turbo high comp n/a motors this requires a remap or aftermarket ecu and some other upgrades like fuel pump , fuel regulator , injectors, manifold ect...
And for it to be a long lasting one they basicly modify the motor to suite valve springs , cams , pistons ect...
So it usualy works out cheaper to buy a turbo car that is already designed to run boost.
With the right tools and right materials we can make anything is possible.
With the wrong tools and wrong materials we learn whats right the hard way!
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901096
12 hours ago, Dose Pipe Sutututu said:
Or buy a Golf GTI, install an intake, a dump/downpipe, and flash it. Will go faster than a 200kW GTS-t boat and has all the luxury, features and safety.
This is a Skyline forum, not a best-bang-for-your-buck forum :P
  • Like 2
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901132
I can confirm that this is fact as I also currently own a flashed MK4 Golf and it hoons
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901221
26 minutes ago, Slap said:
How much did it cost?
Unsure as I bought the car with the flash tune. I think the guy I purchased it off pulled the ECU and had it posted to them, they reflashed it and sent it back. A guy called Gavin did it what currently works for Underground Performance located in Melbourne
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901223
Sorry i ment the car?
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901231
4k, looking at selling it soon if you're interested
https://www.sau.com.au/forums/topic/476369-r33-ecu-remap/#findComment-7901294
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
