I scored these 17inch Nismo rims for my 33 and was wondering how much they might be worth as I can't find them anywhere online as their most likely old school,  but they say Rays Eng on the back (rays engineering) I've found the lmgt wheels look a lot like them but they don't have the groove design mine have.
https://www.sau.com.au/forums/topic/476408-nismo-rims-question/
after researching I found they look a lot like the Volk AV3 rays racing rims the only thing that's missing is the "vr" logo in the middle. I've added both a picture of the volks racing wheel and the rim that I have. It's almost like the middle parts been taken out and the nismo logo has been placed there. Thoughts?
Send through a picture of the bacl of the wheel. I fancy myself a bit of a google slueth. Normally there's a bunch of part numbers stamped into the wheel.
You can normally trace the part number to a brand.
I can't post a picture of the backs at the moment as their already on my car. My last rims were starcorps, and the front ones were wrecked and I picked up a full set of these rims for $400 so I smacked them all on asap so I could go for a drive, I was a bit keen. I went out though and because only two of the rims had the nismo logo on them I was suss, and yep the nismo logo is in fact a sticker. However all the bolts ect say Rays. So I'd say their defiently the volks racing AV3S & the only wheel I can really find that's genuine nismo with a similar design is the LMGT range, I still got the rims cheap I suppose with decent tyres bit shattered now though the excitements worn off and I've over looked them, lol.  The volks racing centre caps have just been removed however the AV3S seem to have "volks racing" written on the side as pictured above,  the ones I have don't as I've looked at the wheels without stickers. The only markings I can see from the front is what looks like the star sign Virgo M (best way to explain it) and "via" written just before it. I'd say their definitely genuine rays though. Hmm. I'm just putting it all together to sell it so I wanted to make sure I know everything that's on it to negotiate a fair price and if I can't find the right wheels online to look at rough second hand prices I'll never know. But I'm sticking with their Volks Racing av3 rims.
  • Like 1
As you've already noticed the NISMO logo is just a sticker, so it's very likely the "Volk racing" in the above pic was also just a sticker that has been removed or deteriorated with age, so i'd agree they're gong to be the Volk AV3 as you've suggested,
  • Thanks 1
Most Nismo stuff is rebadged from other manufacturers so you probably have genuine Nismo wheels made by Rays Engineering. My Bilsteins were labelled "Nismo". Nismo oil is supplied by Motul.
I'll give you $100 for the set if you pay freight?
My partner is saying somewhere on the back of the rim it says nismo but until I take one off to look, the wheels have all the exact same markings and design of the Rays Volks racing av3 alloy wheels,  just without center caps as now I've found the av3s are discontinued and hard to come by.  I paid $400 for the ones I have on now lol so no thank you,  however I do have a set of starcorp 18inch Impuls. All the tyres are shagged,  both rear rims are in good nick except one has scratches. Both front rims are free because they need repairing but you can't buy them anymore, so if you like vintage Shit and starcorp stuff it's alright haha, $200 for those and I'll post no worries. Lol.
Edited by Nikkirosee
If anyone wants these, just ask. $200 tyres are no good, two front rims are free as their chipped and need repairing before use.
I pulled off one set of vintage tyres and ended up with more, think I've done OK there lol.
5 hours ago, lidz said:
Yeah those are Volks with a nismo sticker, as you said centre caps have been removed (they just pop out).
Both are made by Rays Engineering but they're definitely not nismo's.
Yes as soon as I looked closer, I tried to tell my boyfriend their just stickers, he wasn't having a bar of it. So I stalked google asked some pros and now he believes me. The only rays nismo wheels are the lmgt line for GT-RS. While they had the same kind of similar look with the bolts ect I knew they weren't it and it wasn't hard to tell the rays engineering part was legit, I eventually found them. Took a whole day still though to prove my point lol.
2 hours ago, niZmO_Man said:
$400 pretty good for a set of Volk Racing wheels that aren't damaged.
Oh yeah they are in great condition and haven't even gave them polish yet. Will make a nice touch when I sell her.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
