No flex z is twin tube still and not replacement for mono flex which is single tube, that is mono sport. Replacements are:
Tein super street > street advance (both twin tube) still 5 / 4 on bnr32
Tein type flex > flex z (both twin tube) now 7 / 6 on bnr32
Tein mono flex > mono sport (both single/mono tube) now 10 / 8 on bnr32
All construction appears to be of a cheaper construction compared to the old lineup according to a few sources as I was going to get a set of mono sport for my Bcnr33. I think I'll go with the Ohlins mono tube after Tein has changed their lineup.
Why the hell is any "top shelf" damper being made in a twin tube design in this day and age?  FFS!
Because most old school JDM brands never changed design or improved development to modern standard so they got left behind in the 90's.
HKS, Tomei, Tein, Greddy, Defi etc
The part number listed is the full damper kit part number, the part number in your pick above is the damper only part number. I take it that's the rear above, check your front, it should have a different number. Fulcrum suspension being the Tein Australian supplier and service company did release Australian spec super streets also, but I believe the Aussie stuff was made softer than the Jap stuff and don't know if this was done at a spring level or a damper valving level. I would suspect at a spring level as that would be easier than revalving. Give Fulcrum a call to find out as you may in fact have Aussie spec ones. Regardless, the spring rate is probably as listed by Tein.
Twin tube does have it's pros, cheaper construction, lower gas pressures, but mainly that you can damage the outer body and it won't affect the operation of the damper piston moving as that runs on the inner tube. This would be the main reason all oem dampers are this way as if the damper has an external impact and damages the outer body, the damper is not a throw away like a mono tube. Obviously the valving in twin tube dampers is shit because the pistons are so much smaller compared to a mono design and that changes the valving oil orifice size, and why good performance dampers aren't usually twin tube.
That's not true at all. Tein, HKS, Cusco ect. have all made mono tube dampers in the 90's. Tein RA were monotube. HKS hypermax III / IV are monotube, but remember they aren't a suspension company either. Can't really compare HKS, Greddy, ect. to Tein though as they are a suspension company only like Bilstein, Ohlins, Supashock ect. and they offer a much wider range from very entry level to their upper end performance stuff (like the dear as poison $5 - $20k dampers like Super racing, HT, Group N, N1 dampers). It's a shame they have appeared to have cut production costs on their lower end stuff. That said they have just released a proper replacement for the mono flex - the mono racing which is valved like the $5k+ Super racing damper allegedly and is around $2.5 - $3.5k.
At the risk of sounding like a smart ass, there's a lot more to it than 'mono tube are better'
For example, arguably the best dampers in the world the Ohlins TTX 40 are twin tube (that's what the TT stands for)
https://www.ohlins.com/product/ttx40-mk-ii/
Having said that, they are a well researched and engineered solution from a company that expends a huge amount of time resources on a product that works. I think generally speaking for less well resourced/mass market companies a montube is simpler to execute to a higher standard and provides increased flexibility when pushing out designs across a number of platforms.
These are quite specialised twin tube dampers, and are far from comparable to the regular twin tube out there with 20 - 30mm pistons. These have 40mm pistons which are similar to most mono tube dampers at around 40 - 45mm which is important. No doubt a good damper, hey it is Ohlins, and they are specialised suspension.
Usually mono tube is better, above is an exception.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
