I was looking at purchasing these for my R33: https://carbonetics.net/index.php?route=product/product&path=339&product_id=6813
I know they are chinese copies, but are they any good? I am looking for new seats for my r33 which hold better, I was considering R33 GTR seats but cannot find any in good condition for less then $1000 a seat.
Do any brides have ADR compliance?
https://www.sau.com.au/forums/topic/476672-bride-seats-for-r33/
Are you willing to risk your life in them?
If you crash your insurance company won’t pay you anything for having a non compliant item fitted to your car
Have you tried searching yahoo auctions japan for genuine r33 seats?
  • Like 1
Custom fabricated or genuine rails only, another question you should ask is that do you see any WTAC guys cheap out on seats or harnesses?
And no aftermarket seat is 100% ADR, all the advertised crap is just that crap. None of these seats go through crash testing.
For a street car, you can't beat stock GT-R seats from R32 to R34.
Yes I have searched buyee.jp for r33 gtr seats and cannot find anything. I won't buy these, but a lot of JDM parts are not ADR Compliant some of which I have on my car like TEIN coilovers, BLITZ front mount etc etc.
Where can I find some? Any other suggestions on good seats from the likes of Recaro or Sparco? In saying that neither of these are adr compliant are they?
Yes and if you crash and these are on your car and your insurance doesn’t know or hasn’t agreed to cover them then there is a high chance that you will not receive a payout and have to cover any damages from your own pocket
Ok, the seats arrived on Friday. Have to say I am very impressed with the build quality being essentially a Chinese rip off. The recliner is strong and feels robust and the seat is comfortable and holds very well surprisingly. I bought the rails from the same manufacturer I linked in the OP and everything was bolt in. Can't complain for $650 shipped.
Did you pull the seat base apart to have a look at the quality of the welds on the frame?
I did when i had one and was horrified with what i saw. There was holes burnt through the thin metal and instead of throwing it out and starting again they just tacked inside the hole.
Some reps are ok, others are not. You should definitely give the lower base and welds a thorough inspection. You will need to remove the lower fabric and padding. Pretty easy to take off and put back on.
This is assuming they're reclineable and not bucket seats.
  • Like 1
  • 11 months later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
