Just FYI
The 2018 Infiniti Red Sport Q60 with 400 ponys is a bargain at $59,000 when a few people in here purchased there G35/37 for $30,000 and only got 300hp
And tuning is happening in Oz
A Facebook page is up about Infiniti Australia...
Just Fyi
https://www.sau.com.au/forums/topic/476953-a-new-400hp-infiniti-q60rs-59000/
1 hour ago, Leroy Peterson said:
On 5/10/2019 at 5:07 PM, mlr said:
Yeap new and reliable vs ......not
Which one is which??
The Infiniti cost $60k, even adding another $10k that's only $70k to spend, what does that money buy.
A 10 year old GTR for around $75k, but would you, I personally wouldn't touch a cheap 10 year old GTR with a 10 foot barge pole.
Those things cost your kidneys when they break.
I wouldn't touch either, personally.
Q60 ain't gonna be cheap when it breaks either, depending on warranty conditions.
I assume resale value gonna plummet on Q60 too, going as new cars do, while GTR got a pretty strong secondhand market for 2010 and newer.
Flip before end of warranty, easy.
I'm not saying a GTR is a bad buy, I'm saying buying from the bottom of the barrel could be a expensive endevour.
Expensive cars that are being sold at the lower end of the price scale makes my spidey senses tingle.
Opinions may vary
I have had my Q60RS for a 1 1/2 years and there has been nothing wrong with my car...
I’m not too sure where you guys are getting this information from, I know in the forum in America Q50/60 there have been some problems but not my car
 You can buy a 400Hp car without any tuning problems... why not !!
On 5/10/2019 at 5:54 AM, wizlb said:
Just FYI
Just Fyi
The 1995 R33 GTS-T with 450hp is a bargain at 13k...when a few people here purchased their Q60 for $59k and only got 400hp
And tuning is happening in Oz!
A 25 year old modified car with questionable reliability came into this discussion how??
Just seems ridiculous to compare a 60k car to a 30k one, so thought I'd join in the fun.
As for questionable reliability...well...10 years without missing a beat at that power level. But even new VWs are "questionable".
The other 45k saved ought to more than cover anything that goes wrong until the other cars drop to the same value ?
  • Thanks 1
It’s that time Bird..
I had a 96 GTST and spent to damn much to get my car to 400RWHP but it became to old and I had to trade it in
Then I got a 2005 GT350 or G35 and that was to slow but more reliable, but that car became to old too
So, now I have a 400 HP car with damn near 400RWHP but no mods yet and you can get one for that price I posted ... if you can afford one buy one ...
but we all have our opinions and yours is valid to Bird
I had a 96 GTST and spent to much damn money to get my car to 400rwhp but it became to old and I had to trade it in...
Then I got a 2005 GT350 or G35 and that was to slow but more reliable, but that car became to old too....
So, now I have a 400 HP car with damn near 400RWHP without any mods yet and you can get one of these for price I posted, buy it if you can afford one, buy one ...
but we all have our opinions and yours is valid to Bird ....
This Q60 was on E85!!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
