Anyone know what car this spoiler is meant for, it’s an r33 gtr style wing and was sold to me as for an r33 but it’s to wide. I know there was 33 style wings for s13’s and 32’s but i don’t know what it’s specifically for as I want to sell it on as the correct thing. At this point I’m pretty sure it’s not meant for a 2 door 33
https://www.sau.com.au/forums/topic/477167-help-identifying-this-wing/
42 minutes ago, tridentt150v said:
Not sure, actually looks more Supra???
Yeah no idea, it’s got the right angle to mount to the boot like like a standard wing but the base it to wide to fit in the gap between the two rear quarters, here is another post selling what I’m pretty sure is the same as mine as an r33 gtr wing
1 hour ago, GTSBoy said:
Nah, it's going to belong (or not belong, because....shudder, it's so ugly) on a car with a conventional bootline. R32, S13, EB Falcon, etc.
Yeah I’m aware it’s hideos lol but I got it cheap and if it fit then I’d just run it for some shits and gigs, I don’t like it enough to bother putting in work to make it fit so just wanted to see if anyone had any pointers as to what it was so thanks. I think at this point I’ll try to sell it as a generic spoiler and people can see if it fits whatever they want to use it for rather than guessing what it is (what the previous seller likely did)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
