Since we are being philosophical in here, I just want to say that I think there is value in a place where Skyline focused but not single pointed people can discuss cars, in a moderated environment with some minimum level of respect.
There are other places around if you want something else, either less moderated, more generic, or more specific.
Thanks for keeping the place alive for so many years Christian, with recent events I've been thinking a lot about the old days, friends we've made and lost through here and how SAU has made it in one form or another through so much change in the world.
17 years now.
  • Like 5
  • Thanks 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908667
17 years now.
Funny you write this now D I've been thinking about what to do for the 20 year anniversary!!! ?
At the risk of sounding emotional, Its people like you and the others in this thread (sans slap) that make it worthwhile. ?
  • Like 3
  • Thanks 2
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908671
I think we should close the forum and move permanently to Facebook so we can put up with 100 more people like Slap and answer the same questions every day regarding failed AFMs, cam angle sensors and what oil to use in for a basic service.
  • Like 1
  • Sad 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908714
That's pretty much how I look at it. Plenty of people prefer the lack of moderation, quick responses and convenience of facebook.
SAU is deliberately different, and I think the quality of the content is better as a result.
  • Like 5
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908733
Let's have a Skyline remembrance day cruise. Can be a car cruise where we all use our euro SUVs and tow our Skylines on trailers.
At least we won't be defected or end up on Today Tonight
  • Like 2
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908737
hahahaha, if only they didn't come factory with hoon bars. What ever would we do.
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908811
The age of facebook being preference is surely dying. I find it a very hard place to take things seriously purely due to those reasons you mention.
And I agree content quality is far better on SAU.
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908816
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908818
Bingo. Old man style, I rather these forums stay in the format. Easy enough to search through.
If you want to type incoherent shit with a random picture that has nothing to do with your post, do it on shitbook.
  • Like 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908825
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
