Since we are being philosophical in here, I just want to say that I think there is value in a place where Skyline focused but not single pointed people can discuss cars, in a moderated environment with some minimum level of respect.
There are other places around if you want something else, either less moderated, more generic, or more specific.
Thanks for keeping the place alive for so many years Christian, with recent events I've been thinking a lot about the old days, friends we've made and lost through here and how SAU has made it in one form or another through so much change in the world.
17 years now.
  • Like 5
  • Thanks 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908667
17 years now.
Funny you write this now D I've been thinking about what to do for the 20 year anniversary!!! ?
At the risk of sounding emotional, Its people like you and the others in this thread (sans slap) that make it worthwhile. ?
  • Like 3
  • Thanks 2
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908671
I think we should close the forum and move permanently to Facebook so we can put up with 100 more people like Slap and answer the same questions every day regarding failed AFMs, cam angle sensors and what oil to use in for a basic service.
  • Like 1
  • Sad 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908714
That's pretty much how I look at it. Plenty of people prefer the lack of moderation, quick responses and convenience of facebook.
SAU is deliberately different, and I think the quality of the content is better as a result.
  • Like 5
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908733
Let's have a Skyline remembrance day cruise. Can be a car cruise where we all use our euro SUVs and tow our Skylines on trailers.
At least we won't be defected or end up on Today Tonight
  • Like 2
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908737
hahahaha, if only they didn't come factory with hoon bars. What ever would we do.
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908811
The age of facebook being preference is surely dying. I find it a very hard place to take things seriously purely due to those reasons you mention.
And I agree content quality is far better on SAU.
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908816
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908818
Bingo. Old man style, I rather these forums stay in the format. Easy enough to search through.
If you want to type incoherent shit with a random picture that has nothing to do with your post, do it on shitbook.
  • Like 1
https://www.sau.com.au/forums/topic/477433-why/page/2/#findComment-7908825
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
