Hey everyone,
Need a new clutch for more power / current one is worn, I have the GTT (RB25DET Neo) was wondering if anyone has any tips on what to look for?
Will any aftermarket single plate do? Currently looking at https://www.gameonmotorsports.com.au/npc-nissan-skyline-r33-gtr-pull-type-clutch-r34-gt~44571
Looking to make about 375kw~
Edited by thenixtone
https://www.sau.com.au/forums/topic/477812-suggestions-on-a-new-clutch/
10 minutes ago, thenixtone said:
Ah right, my bad, I thought this was a forum.. for discussions. A clutch place isn't going to tell me if their clutch is shit, are they?
Maybe they would if you asked about an unsuitable model in a particular application.
call npc. Tell them what you want. Call Jim Berry. Call acs
On that basis, we could trot out the passive aggressive claim that no-one has ever asked that question on this forum before and that it would be impossible to search for previous/recent discussion.
You mean like the original passive aggressive comment I was responding to?
And of course I searched. Its hard to find information with exact power figures. How do you think I came across the NPC clutch that people on here recommend..?
Every thread that COULD be answered elsewhere is useless apparently.
Besides 'this one fits' I was after actual experiences and feedback.
Budget? Where/how you are using the car?
I have ACT 6 Puck with Extreme pressure plate (rated to 830nm iirc) on my rb30/25 street car (550hp/730nm) and Im happy with it. We dont really have bad traffic here where I live though
On ‎18‎/‎07‎/‎2019 at 4:46 PM, WR33KD said:
OS R3C here aswell, only clutch you will ever need
In a rwd application under 400kw yes, so fine for the GTT in this application, but not in a GTR launching at 7000rpm +. I killed a brand new one in one drag weekend, completely warping the metallic floating discs to the point the clutch wouldn't disengage.
Probably not relevant in this situation, but just pointing out that they are not the "be all to end all" of clutches at all. They also drive like shit on the street, very hair trigger engagement.
  • Like 1
2 minutes ago, WR33KD said:
Mines mint she feels like a standard clutch, done plenty of hard take offs and still feels great. I’m over 400kw and rwd and it’s the bees knees and it has a changeable centre not like others
What you got?
Jesus..
Is the difference between button and cushion button that big of a deal for street driving?
29 minutes ago, thenixtone said:
What you got?
Jesus..
Nope. The cushion has very little effect. A button clutch is going to be pretty much off or on and  don't like slipping
All multiplate clutches have a changeable centre hub by design, so thats not anything special. Maybe your R3C seems a bit nicer to drive in a rwd car, because any metallic triple plate I've had in a GTR has a hair trigger and not really slippable, definitely nowhere near a standard or full face clutch plate type. I've had ORC (Ogura), Xtreme (ACS), Exedy and OS Giken all in triples and all basically felt like the same clutch.
OP, The Nismo twin, NPC twin or even the OS giken TS2B will probably be a nicer clutch to drive for you and handle your power for quite sometime. $1500 or less though is going to limit you to buying a single plate though, as I think you'll need to stretch a bit more to at least go a twin or triple if you can afford it.
Awesome, thanks for the info. Think I'm going to spend the money and get the coppermix.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
