I want to get those fake replica nismo aluminium oil filler caps from eBay but I’m a bit weary on them. Do you think they can hold up to the oil pressure from engine? I mean if oil pressure gets high enough wouldn’t it start leaking or even worse, blow straight off? There’s also the problem of threading when putting it on and off.
its just purely for asesthic reasons why I want one but I’d like to hear some thoughts and opinions on them
thanks
https://www.sau.com.au/forums/topic/478727-are-aluminium-oil-filler-caps-safe/
And considering that the original cap is plastic...……..well how much pressure do you think plastic would take in comparison to alloy?
I've got a half piston type anodised blue one with Tomei on it, and its harder to undo than the factory one cos there is no grip on it.  Sometimes I have to use a screwdriver in the fake gudgeon pin hole to start it.  I always tell myself that one day I will dig the factory cap out and use it, but I never seem to....maybe its the bling?
  • Like 1
Is the correct dimension 6cm diameter , 3.1cm height and 32mm thread
or
5.7cm diameter, 3.2 height and 32mm thread
thanks it’s for rb25det neo
Edited by IM-32-FK
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
